I have a problem, return to the -22 error in the request_irq function call.
Register interrupt device is the FPGA side PushButton, offset address is 0x000100c0 The following is the content of the button_pio device tree. The priority of button_pio is FPGA_IRQ5,Find in Handbook, The 77 is the corresponding interrupt number(#define FPGA_BUTTON_DSR_IRQ 77). button_pio: gpio@0x1000100C0 {compatible = "ALTR,pio-13.1", "ALTR,pio-1.0", "altr,pio-1.0"; reg = < 0x00000001 0x000100C0 0x00000010 >; interrupt-parent = < &hps_0_arm_gic_0 >; interrupts = < 0 45 1 >; width = < 2 >; /* embeddedsw.dts.params.width type NUMBER */ resetvalue = < 0 >; /* embeddedsw.dts.params.resetvalue type NUMBER */ edge_type = < 1 >; /* embeddedsw.dts.params.edge_type type NUMBER */ level_trigger = < 0 >; /* embeddedsw.dts.params.level_trigger type NUMBER */ #gpio-cells = < 2 >; gpio-controller; The following is the driver code. writel(pst_pio->np_pioedgecapture|0x1, &pst_pio->np_pioedgecapture); writel(pst_pio->np_piodirection&0xfffffffe, &pst_pio->np_piodirection); ret = request_irq(FPGA_BUTTON_DSR_IRQ, button_dsr_isr, IRQF_DISABLED, "button_dsr_fpga", (void*)(pst_dev)); if (ret != 0) { printk("button_dsr: unable to register interrupt %d\n", ret); return -1; } writel(pst_pio->np_piointerruptmask|1, &pst_pio->np_piointerruptmask); comment out "interrupts = < 0 45 1 >;" after successful registration, interrupt can also be normal response. what is the reason? If you have any ideas would be greatly appreciated.ThanksLink Copied
Help please! Somebody help me!
For more complete information about compiler optimizations, see our Optimization Notice.
