Reset Vector on Flash Memory
I'm new in Nios II and have two questions for you.
I want to control my Clocked Video Input and Output via Nios II.
First question:
I begin my Nios II experience with this training video:
http://www.youtube.com/watch?v=t-npunz49ny (See his configuration at 7:40)
The Hello World works fine with onchip memory, but if I want to connect a flash memory for the reset vector, i become this two errors:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6641
Why did I become this errors and why does the guy from the video does not have them?
Second question:
In this .pdf on page 120
http://www.altera.com/literature/ug/ug_vip.pdf
I see that I can output the video, by using the control register bit 0.
How do I configure this in NiosII?
I think that I have to write something like this:
cvo_0.control(0,1);
but wherefrom do I know the correct syntax?
Thank you very much.
First question: solved
Before lunch, I have closed Quartus II. After it, I reopend it. Aaand: No more errors... However
Still trying to configure the registers.
