I'm running a program in NiosII that read and write files in my host PC. For that I'm using the NIOSII IDE. As I have to repeat this running several times, i'd like to make this run full automatic so I don't need to enter in the graphical mode every time. For that i'm having a problem in trying to run niosII program because using the command line, i'm not being able to mount the hostFS. Does anybody know how can I do that? So far, my script to program FPGA + run NIOSII project has the following steps: 1- Program FPGA >> quartus_pgm -c "<usb-blaster name>" <file.cdf> 2- Build nios project: >> nios2-build-project --projectName=<projectName> 3- Configure Nios >> nios2-configure-sof <sof_file.sof> && nios2-download -g <file.elf> 4.1- Open Nios terminal to check output of running program (in one linux terminal) >> nios2-terminal 4.2- Run program in Debug mode (required for hostFS to work) -- in another linux terminal >> nios2-debug <file.elf> Once again, following this steps I cannot access the file to read and write because I think hostFS is not mounted on /mnt/host Using IDE the program works fine. I'm using quartus + Nios2-IDE version 10.1 regards,Link Copied
