Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
SD Card Controller core for NIOS?
Hi!
Someone knows where I can buy SD Card Controller core for NIOS2 and
how much it will be cost?
Thank you.
Highlighted
Re: SD Card Controller core for NIOS?
Have you figured out an answer to this yet? I may be interested in an SD Card interface too.
Anyone?
tjd
Highlighted
I am not personally aware of any SD Card IP for Nios/SOPC Builder - sounds like an interesting project! Is there any SD Card access IP on opencores.org? Some of their IP (wishbone compatible) interfaces well to Avalon.
Highlighted
The SD card ref design I saw posted is used to boot an FPGA from an SD card using a CPLD. Haven't looked through the code as yet though.
Highlighted
I have designed one, but support read only,include single block read and multiple block read.
