when I try to start the university test program in Eclipse, it says that the sdcard is inserted but the File System is unkown. I tried with different sdcards but the problem remains. I tried to debugging and I found where the problem is. Please check the code for the red line. This is the part where the program returns result = false, and I get the message "Unknown File System". I don't really know what I should try now. Any help is appreciated. Thank you in advance. Please aks me if you need further information. Information SD-Card: sdcard 256 mb - FAT16 format - tried with 4kb, 8kb, 16kb cluster size Information about the SoPC: Avalon_UP_SD_Card_Interface_0 component is connected to: avalon_slave_0 to cpu.data_master clock_sink to pll.c0 (pll.co = 50 MHz) clock_sink_reset to pll.requestreset conduit_end is wired to nothingbool Check_for_Master_Boot_Record(void)
// This function reads the first 512 bytes on the SD Card. This data should
// contain the Master Boot Record. If it does, then print
// relevant information and return true. Otherwise, return false.
bool result = false;
int index;
int end, offset, partition_size;
/* Load the first 512 bytes of data from SD card. */
if (Read_Sector_Data(0, 0))
end = (*((volatile short int *)SD_CARD_BUFFER(device_pointer->base, 0x1fe)));
// Check if the end of the sector contains an end string 0xaa55.
if ((end & 0x0000ffff) == 0x0000aa55)
// Check four partition entries and see if any are valid
for (index = 0; index < 4; index++)
int partition_data_offset = (index * 16) + 0x01be;
char type;
// Read Partition type
type = (*((volatile unsigned char *)SD_CARD_BUFFER(device_pointer->base, partition_data_offset + 0x04)));
// Check if this is an FAT parition
// This is where the program can't find any type of those below
if ((type == 1) || (type == 4) || (type == 6) || (type == 14))
// Get partition offset and size.
offset = ((*((unsigned short int *)SD_CARD_BUFFER(device_pointer->base, partition_data_offset + 0x0A))) << 16) | (*((unsigned short int *)SD_CARD_BUFFER(device_pointer->base, partition_data_offset + 0x08)));
partition_size = ((*((unsigned short int *)SD_CARD_BUFFER(device_pointer->base, partition_data_offset + 0x0E))) << 16) | (*((unsigned short int *)SD_CARD_BUFFER(device_pointer->base, partition_data_offset + 0x0C)));
// Check if the partition is valid
if (partition_size > 0)
result = true;
fat_partition_size_in_512_byte_sectors = partition_size;
fat_partition_offset_in_512_byte_sectors = offset;
break;
return result;
