12604 Discussions
SDRAM DDR2 support in Cyclone soc memory controller
Hi All, I 'm new in this area, let say I found one ddr2 module which want to use by the soc. dow do we know if this module is supported and working?? any fast trick or quite to find out?
I need to say that, actually it is hard to just confirm by just reading the data sheet and parameters. The first step is to try to put all the frequency, row or column into the PHY sdram and try a complete full from HD and full compilation, this is the first step to ensure it is pass at the first place.
Okay.. good
probably at the end still need to test on a hardware for some memory test to confirm the stability.
alright, will be back if get in trouble.
