Chapter 25 of embedded peripherals ip user guide describes SGDMA Controller Core. There is a section that lists resource usage and performance for the core. The numbers look very impressive. Are designs available for download?
I am trying to use SGDMA for MM to MM transfer using HAL APIs and the throughput numbers are very bad. RegardsLink Copied
