Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
SOPC bugs
I keep running into a little problem with SOPC builder producing the following Error!
no slave id!
at the
Making arbitration and system (top) modules.
stage of generation
I start with a simple design, as follows
1 interface to user logic.. an AHB master port.
1 AHB to avalon bridge
1 SDRAM controller
I can build this design.. with the interface to user logic connected my external logic.. and it works great.
but when I add a nios2f and some internal SRAM..
I get the error above?
If I delete the nios2 and sram... (ie back to where I started.)
I still get the error above...
Any clues as to why and what to do would be of great use!
Cheers
