I keep running into a little problem with SOPC builder producing the following Error! no slave id! at the Making arbitration and system (top) modules. stage of generation I start with a simple design, as follows 1 interface to user logic.. an AHB master port. 1 AHB to avalon bridge 1 SDRAM controller I can build this design.. with the interface to user logic connected my external logic.. and it works great. but when I add a nios2f and some internal SRAM.. I get the error above? If I delete the nios2 and sram... (ie back to where I started.) I still get the error above... Any clues as to why and what to do would be of great use! CheersLink Copied
