SPI Slave firmware upgrade
Hello folks !!
I'm writing because I need some suggestions on how to upgrade the firmware on a SPI slave. In this scenario I have a .txt file which contains the bytes I need to send, via SPI protocol, to a SPI slave hardware.
The best thing I have tought is to open the .txt and copy its content into a variable. The problem is that the firmware has 224 KB size for a total of about 57K element.. And I have to initialize the variable by hand.. element x element...
Any suggestions ??
Thank you for help !!
Could you be more precise?
I guess you can copy your text file to flash, read it from there to ram and from ram send the data to SPI slave.
Hello guys.
I'v found the solution here:
http://www.alteraforum.com/forum/showthread.php?t=31611
