- Email to a Friend
hi,
I am using spi core to configure registers of clock chip generator cdce72010. when i read back values from the registers of the chip i get a junk value first, then again when i sent a command to read the value, i get the correct value. why is this ? is it because a junk value is already present in the receive shift register? but if that is the case, i get the junk value when i read reg0, i get reg 0 's value when i read reg1, junk value when i read reg2, i get reg2's value when i read reg3. how could this happen?Link Copied
Topic Options
