Within IO header file for the NIOS toolchain there is a definition 'SYSTEM_BUS_WIDTH'.
Can anybody tell me where this is defined, I have done a search for the string and found nothing so far Thanks SteveLink Copied
It's defined on the compiler command line. The automatically generated file generated_all.mk contains this, this can be found in the system_description directory of your system library.
Thanks for the info.
Steve
