12603 Discussions
SYSTEM/SIMULATION/MODELSIM woes
I am writing a class.ptf file that has a MODULE_DEFAULTS/SIMULATION/MODELSIM section as follows:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
MODELSIM
   TYPES
   SETUP_COMMANDS
      ops = "virtual type {OR AND XOR NOT MOV ADD SUB CMP LSLI LSRI ASRI ROTI MOVI ADDI SUBI CMPI LD {5&#39;b10100 ST} {5&#39;b11000 BR} BSR RET {5&#39;b11111 IFS} {default ILL}} Opcode";
      conds = "virtual type {nc c nz z pl mi lt ge gt le nv v hi la {default ill}} Condition";
      opc = "virtual function {(Opcode) (__MODULE_PATH__/next_instruction[4:0])} opcode";
}[/b]
--- Quote End ---
and this gets transferred over to the system ptf file as you would expect, but when I generate the project in SOPC Builder, I get a rather lengthy set of errors, starting with
--- Quote Start ---
Bareword found where operator expected at (eval 2) line 236, near "&#39;ops = "&#39;virtual"
(Missing operator before virtual?)
Bareword found where operator expected at (eval 2) line 236, near "&#39; ,[OR AND XOR NOT MOV ADD SUB CMP LSLI LSRI ASRI ROTI MOVI ADDI SUBI &#39;CMPI"
(Missing operator before CMPI?)
Bareword found where operator expected at (eval 2) line 236, near "&#39; ,[5&#39;b10100"
(Missing operator before b10100?)
String found where operator expected at (eval 2) line 236, near "5&#39;b11000 BR], &#39;"
(Missing operator before &#39;b11000 BR], &#39;?)
Bareword found where operator expected at (eval 2) line 236, near "&#39;b11000 BR], &#39;BSR"
(Missing operator before BSR?)
Bareword found where operator expected at (eval 2) line 237, near "&#39;conds = "&#39;virtual"
(Missing operator before virtual?)[/b]
--- Quote End ---
Now apart from the fact that the error messages are even less readable than the PTF format itself, I have no idea what&#39;s wrong, even after looking at the few Nios PTF&#39;s for old boards that contain MODELSIM sections.
Before anyone suggests this, getting rid of the {n NAME} bits from the virtual type command and having a pure {NAME NAME NAME} command doesn&#39;t make any significant difference, and anyway I suspect it is not the command itself that is getting complained at.
Many thanks for anyone who can help.
Never mind, this seems to have fixed itself now.
