12600 Discussions
Sampling Multiple Channels with the ADC at The Same Time
Hello everyone,
I am currently trying to sample two differential signals at the same time and I was wondering if there is an easy way to do this in the c code. I can currently sample one channel using the adc code provided in the DE1_SoC_ADC file provided in the CD. However, I cannot find good documentation on how the code works for me to properly adjust the code. I know I can accomplish this task by independently turning on the ADC for one channel, record data, turn off that channel. Then, turn on the other channel and sample. However, I feel as though I will not be sampling at the proper rate if I do this. Any ideas? Thank you in advance.
To give more information, I am using the Qsys editor with the adc_ltc2308 block. I am guessing that I have to edit the block to take 2 bit inputs as opposed to the default 1 bit option.
--- Quote Start ---
--- Quote End ---
It is not matter of coding. An ADC has to sample analogue signal and I never heard of a single ADC sampling multiple channels in time sharing way. Use two ADCs then do your processing shared in digital domain.
--- Quote Start ---
--- Quote End ---
Okay, am I not understanding this paragraph in the manual? http://www.alteraforum.com/forum/attachment.php?attachmentid=11287&stc=1
It says that the ADC can be configured to accept eight input signals.
it means 8 ADC devices to me (call it channels).
8 inputs to 8 ADCS (one input per ADC)
8 outputs from 8 ADCs, at this side the speed of each ADC output being 500Ksps Versus serial clock of 40MHz is exploited to que them up as 500Ksps *8 = 4MHz
--- Quote Start ---
--- Quote End ---
I did some more research. That statement does not mean that there are 8 ADCS. There are 8 input pins that are connected via a mux which then goes into a single ADC. I am just going to write some code to ping between two channels and see how that works.
--- Quote Start ---
--- Quote End ---
ok with such slow ADC it is possible to mux any number of inputs so one adc is time shared between them like a queue.
As such what matters to you should be how read the relevant channel in the queue. This info should be available to you from vendor.
