12453 Discussions
Share variables and data between Nios2 and HDL prefably VHDL
Hi
How do I send data from Nios 2 processor to HDL in quartus. I need to send data such as a variable i.e. a=5; or array[20] to the vhdl side in quartus. How do I set up a shared memory space. I am using the Altera DE3 board. Please explain to me carefully, I have around 4 months of vhdl and fpga experience.
Reigngt09
Simplest way is through an avalon MM slave.
How would I go about implementing the avalon MM Slave to send data through?
On the HDL side refer to the avalon specification:
http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
On NIOS side use "IORD" and "IOWR"
poking through some of the nios example templates will help with learn how to do this
Hi
i also would like to know how this works.
In my project i want to send some control parameters to the Nios processor via the rs232 interface.
Nios should then store them in some kind of a shared memory location where my custom vhdl logic reads from.
I read that i could use a DMA or SGDMA Controller but this seems a bit of an overkill since i just want to sent parameters.
I know the address range of my DDR3 RAM and how to write to a specific address. But i have a understanding problem with
the reading part.
I need an avalon slave device which i hook up to the avalon interconnect.
Could i simply use a FIFO in write/read slave modus?
If i connect the NIOS instruction and data master with the slave-in port and export the slave-out port to connect it up my logic.
With C i then write directly to the Fifo buffer and the vhdl logic reads from the buffer directly.(?)
Since only master-slave connections are allowed my logic to act as a master and initiate the read operations.
and the vhdl module needs a lot of control functionalities like readdata, read address ?
Or is it easier to use a onchip memory ram device with dual port access.
I could write a specific parameter to a specific mem address and through this exact mapping its simple in
VHDL to extract the parameters.
But i still have the uncertainty with the slave port to the vhdl module and in general how to set up this shared memory location.
The more i read about this topic the more i get confused and
it would be great if you guys could help me
Thanks in advance
Tim
