12600 Discussions
[Shell Script failled] EPCS based Remote System Update (RSU) example on BeMicro SDK
Good morning all,
I tried to build the example given at that address : http://www.alterawiki.com/wiki/epcs_based_remote_system_update_(rsu)_example_on_bemicro_sdk . It's an example of RSU for BeMicro.
I have downloaded the 20120130_bemicro_sdk_epcs_rsu_11.1sp1.tgz (http://www.alterawiki.com/uploads/a/a6/20120130_bemicro_sdk_epcs_rsu_11.1sp1.tgz) file, extract it and execute the top_build_everything_ser.sh but I get a lot of errors :
ERROR: File project_sources/demo_images/factory_hw.flash is absent.
ERROR: File project_sources/demo_images/factory_sw.flash is absent.
ERROR: File project_sources/demo_images/app_hw.base64 is absent.
ERROR: File project_sources/demo_images/app_hw_sw1.base64 is absent.
Can anyone try to build this example and tell me if you get the same problem ?
I cannot figure out why I got this.
Thank you.
Flandroid
I found why, I have the new version of Quartus and the exemple is for an old one.
While the name of the file implies (20120130_BeMicro_SDK_EPCS_RSU_11.1sp1.tgz) Altera ACDS 11.1sp1.
The link
http://www.alterawiki.com/wiki/epcs_based_remote_system_update_%28rsu%29_example_on_bemicro_sdk
States 'This example was created and tested with the Altera ACDS 11.0sp1 development tools.'
I tried with both versions of tools, the installations of which take up as much bleedin' room as Siberia on my hard drive, and I still get the errors
ERROR: File project_sources/demo_images/app_hw_sw1.base64 is absent. etc. etc. etc.
Altera software 'quality assurance' by the look of it..... Unless anyone has any other ideas?
--- Quote Start ---
Good morning all,
Thank you.
Flandroid
--- Quote End ---
I am seeing the same problem. Did you figure out why? I have Quartus II 13.0.. but I installed Quartus II 11.1 still have the same issue...
--- Quote Start ---
Good morning all,
Thank you.
Flandroid
--- Quote End ---
I have the same problem. Is it because I have a newer version of Quartus II (13.0) vs the required Quartus II (11.0) ???
I tried install the correct version of Quartus II. Still doesn't work. Anyone who can help?? Thanks
--- Quote Start ---
--- Quote End ---
I think I used a different example.
Either that or I installed 11.0sp1 or 11.1sp1 to get it to work.
A right royal headache.
--- Quote Start ---
--- Quote End ---
Any chance you can share the example. I have exhausted all options.
--- Quote Start ---
--- Quote End ---
I used AN603 and modded it into my design. See attached.
