Signatures
I am trying to use abstract classes in GNUPro C++ for Nios.
Using the makefile example structure, I wrote inside the "-fhandle-signatures" directive, as described in the gnu-gcc document which comes with Nios. The compiler returns that it do not know this directive.
Does anybody have worked with signatures in Nios software? How can I use it ?
Thanks in advance,
Flavio
