12600 Discussions
Simple Socket Server for Cyclone 10 GX Kit
JLee25
Hell,
I am looking for SSS reference design for this kit.
Do you know where I can find it?
Thank you!
BRs,
Johnson
Deshi_Intel
HI Johnson, The answer stay the same on the other 10M/100M MII forum question thread that I replied to you earlier. Intel doesn't has SSS reference design for Cyclone 10 GX but we do have it for Arria 10 FPGA that you can take a look at. https://fpgacloud.intel.com/devstore/platform/17.1.0/Pro/arria-10-nios-ii-simple-socket-server-design-example/ Thanks. Regards, dlim
JLee25
Hi Dlim,
Thank you for the reply.
I am curious to know why there's a SSS example in C10 GX kit example folder.
I download the sof and the SSS start running but I was not able to connect it through TCP.
Would you help me check this example?
Johnson
Deshi_Intel
Hi Johnson, Thanks. I am not aware of SSS example design in Cyclone 10 GX dev kit example folder. Let me take a look on the example design and also find out if there is specific requirement in using this example design. Thanks. Regards, dlim
Deshi_Intel
Hi Johnson,
I took a look on the design. It does seem like SSS example design.
You can find out more about the design detail and usage in following readme.txt file
\simple_socket_server\software\app
dlim
