Strange DMA Transfer
Hello, everyone. I'm the one of engineers to struggle with NIOS2.
I want to use DMA in 16bit mode.
The following data is transfered from main memory(SDRAM in my kit) to peripheral.
DATA: 0000h 01E0h D33Ah ... (continued)
Next image describes well.
wave form (http://www.drvbox.com/wave08.gif
But, the first data(0000h) appears during 4 cycles and next data(01E0h) appears two times again.
I cann't understand that situation.
I tried to use DMA-transfer from main memory(SDRAM in my kit) to the same(SDRAM in my kit) in 16bit mode.
And I experienced the same case. I think, DMA may have problem.
At the end of Develpment of my product, I have been much anxious about the problem.
Please, help me, Nios Users and ALTERA !
Good luck to every Nios Users.
I just tried the experiment of transferring data to and from SDRAM in 16-bit mode (for a 32-bit SDRAM) and it seems to work fine.
Can you post your code which does the 16-bit SDRAM transfer?
