Strange Nios latency
I have SOPC Nios system with onchip_mem. Program (resides in onchip_mem) works very slowly.
In SignalTab I see strange Nios latency.
Time between two simple writes is 48 Nios clock cycles! Why so? I suppose it should take 4 cycles.
Test example
int main()
while(1)
IOWR(0x00020000, 0x1, 0x1);
IOWR(0x00020000, 0x2, 0x2);
What is there at that address? Is it a component? Does it freeze the CPU with a wait_request signal? Is that component or the on-chip memory shared with another master? Is that master active?
And if the slave is in a different clock domain than the master then the handshake can take some time too
Also check the read latency setting in the onchip_mem properties. It defaults to 1 cycle, but maybe you inadvertently changed it.
Master only one - Nios, clock is the same.
0x00020000 is onchip_mem and it haven't wait_request.
How I can understand does Nios stalls or it have some activity? :confused:
Read latency=1,
In onchip_mem.v I see: the_altsyncram.outdata_reg_a = "UNREGISTERED"
while in doc "On-chip memory components use synchronous, pipelined Avalon-MM slaves"
What is correct?
Is the memory block 32bite wide?
Also look at the generated code, how many instructions are there between the memory cycles?
--- Quote Start ---
--- Quote End ---
Onchip is 32bit wide.
One IOWR (Nios IDE> Disassembly Window) have 4 instruction. So the time between real write (stwio) is 5 cycles. I have 55 cycles (for this code) >> 11 cycles for 1 instruction. ??? :mad:
0x0001007c <main+32>: movhi r3,2
0x00010080 <main+36>: addi r3,r3,4
0x00010084 <main+40>: movi r2,1
0x00010088 <main+44>: stwio r2,0(r3)
0x0001008c <main+48>: movhi r3,2
0x00010090 <main+52>: addi r3,r3,8
0x00010094 <main+56>: movi r2,2
0x00010098 <main+60>: stwio r2,0(r3)
Found ! Nios adds 8 cycles to every instruction when you run in debug mode. I compiled program as Release and Run program. In Signal Tab see 2 cycles for IOWR.
Thanks all ! ;)
You've not said which cpu you are using (/f /s or /e).
Are you executing the code out of tightly coupled memory, or via the instruction cache?
If you are using the instruction cache and are looking at the first 2 writes, then there may be instruction cache fills taking extra time.
In that case, the times between the later writes would be faster.
The /f cpu will execute 1 instruction every clock (from tightly coupled instruction memory or instruction cache). 11 clocks is somewhere near the value for a clock crossing bridge (10 clocks??).
I've measured 3 clocks for Avalon MM transfers to local PIO (1 clock delay configured for reads and writes), on chip memory might to 0 clock delay writes.
