12409 Discussions
TCP/IP Stack error: undefined reference to 'alt_iniche_init()'
I am using Nios II IDE 9.0SPE build 235 to implement web server on nios processor with ucOS.
I added the software component 'NicheStack TCP/IP Stack' through Properties.
I get the below error:
undefined reference to `alt_iniche_init()'
undefined reference to `dhc_set_callback(int, int (*)(int, int))'
undefined reference to `dhc_set_state(int, int)'
undefined reference to `netmain()'
In the syslib folder > Debug > obj > iniche and rest of the TCP/IP folders are present
How do I debug this issue? What else should be done so that the system know about `alt_iniche_init()' ,etc?
Code (partial):
# include <stdio.h>
# include <math.h>
# include <unistd.h> // <bae> Allows usleep() to be called
# include <alt_iniche_dev.h>
/* Nichestack definitions */
# include "includes.h"
# include "ipport.h"
# include "libport.h"
# include "osport.h"
# include "tcpport.h"
# include "net.h"
# include "dhcpclnt.h"
# include "icmp.h"
/* Low-level network */
# include "triple_speed_ethernet_regs.h"
# include "iniche/triple_speed_ethernet_iniche.h"
# include "iniche/ins_tse_mac.h"
# include "net.h"
# include "icmp.h"
void SSSInitialTask(void *task_data)
wait_on_phy();
dhc_set_callback( 0, ws_ipset );
alt_iniche_init();
netmain();
while (!iniche_net_ready)
TK_SLEEP(1);
OSTimeDlyHMSM(0, 0, 3, 0);
printf("\nNios II Simple Socket Server starting up.\n");
while (1); /* Correct Program Flow should never get here */
Also... In system.stf
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
<sw_component id="INICHE" name="NicheStack TCP/IP Stack" sopc_component_dir="altera_iniche">
<sys_defines>
<define name="dhcp_client" quote="no" value="1"/>
<define name="ip_fragments" quote="no" value="1"/>
<define name="include_tcp" quote="no" value="1"/>
<define name="iniche_default_if" quote="yes" value="triple_speed_ethernet_mac"/>
--- Quote Start ---
<sys_defines>
--- Quote End ---
@ ash
what's the modification on this file?
There is no modification on this file, .stf is generated by the system.
I think, I need to change the ipport.h, is it right?
Also, in nios II 9sp2, after adding the software component of TCP/IP stack, should I link the src (source code) to the project separately?
