12600 Discussions
TSE and UDP packet offload
I'm using hardawre Nios II UDP Offload System with nios2-uClinux
here is the soft configuration :
--- Quote Start ---
const char *addr[] = {
"192.168.10.170",
"192.168.10.16"
unsigned char the_dest_mac[6]={0x00,0x1A,0xa0,0x0d,0x09,0x19};
unsigned char my_src_mac[6]={0x00,0x07,0xED,0x0D,0x09,0x19};
void connectSocketUDP()
if(( id_socket = socket(AF_INET, SOCK_DGRAM, 0)) == -1 )
{perror("----------------------------Server-socket() id_socket error lol!");
disConnectSocketUDP();
if(bind(id_socket, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1) /*! associate the id_socket to adress server*/
{ perror("----------------------------Server-bind() error lol!");
addr_len = sizeof(struct sockaddr); /*! get the length of struct sockaddr*/
isconnectedUDP=1;
int main(int argc, char *argv[])
while(exit==0)
if(isconnectedUDP == 0)
{ connectSocketUDP();
else
if(start == 0)
{my_src_ip = inet_addr(addr[0]);
the_dest_ip = inet_addr(addr[1]);
insert_stat.udp_dst = MYPORT;
// we fill out this insert_stat struct to pass into the
insert_stat.udp_src = MYPORT;
// payload inserter utility function
insert_stat.ip_dst = the_dest_ip;
insert_stat.ip_src = my_src_ip;
insert_stat.mac_dst_hi = (the_dest_mac[0] << 24) | (the_dest_mac[1] << 16) | (the_dest_mac[2] << 8) | (the_dest_mac[3]);
insert_stat.mac_dst_lo = (the_dest_mac[4] << 8) | (the_dest_mac[5]);
insert_stat.mac_src_hi = (my_src_mac[0] << 24) | (my_src_mac[1] << 16) | (my_src_mac[2] << 8) | (my_src_mac[3]);
insert_stat.mac_src_lo = (my_src_mac[4] << 8) | (my_src_mac[5]);
if(start_udp_payload_inserter(inserter_bases[0], &insert_stat))
{ continue;
[/INDENT] if(start_packet_generator(generator_bases[0],(unsigned short)requested_packet_length, 0x33557799))
{ continue;
start = 1;
[/INDENT]} sleep(10);
stop_packet_generator(generator_bases[0]);
stop_udp_payload_inserter(inserter_bases[0]);
return 0;
--- Quote End ---
using a packet sniffer on a PC, i receive frames but not UDP (protocol 0x0919) !!
--- Quote Start ---
SOURCE : 09:19:00:07:ed:0d
DESTINATION : 00:00:00_1a:a0:0d:09:19 (2 bytes inserts from API component)
Protocol (Unknow) : 0x0919
info : Ethernet II (data 800 bytes)
--- Quote End ---
the only difference with the example in altera wiki is the clock signal (60MHz for the GEN et INS component)
Thanks for help
the problem come from alignment_pad_inserter component, it inserts two pad bytes at the beginning
is it necessary to use it?
It is necessary if you enable the pad option in the TSE settings in Sopc builder/QSys. This option makes life easier for some drivers. You can disable the option in the TSE and not use the alignment_pad_inserter component, but then you might run into trouble if you use the TSE with software.
the SOPC option to enable the pad is it : Align packet headers to 32bits?
When i Enable the pad option using API component i have this frame
--- Quote Start ---
00:00:00:1a:a0:0d:09:19:08:00:45:00:03:3c:00:00:40:00:ff:
11:6d:1b:aa:0a:a8:c0:10:0a:a8:c0:1f:f5:1f:f5:03:28:00:00:
fd:31:03:24:1c:ba:97:d9:0e:d9:2e:77:52:cb:02:3f:d0:fe:7b:
4f:97:59:9d:48:62:c8:dc:61:d0:ac:bf:8f:8d:34:25:47:1e:30:
dc:39:3d:9d:ba:7d:2b:54:82:fa:e2:30:92:b1:bd:a9:89:8d:2c:
--- Quote End ---
if i keep this option enable and i remove API component i have the correct UDP frame
--- Quote Start ---
--- Quote End ---
Yes this is the right option. What you report is strange, it's almost as if you had two pad insertions.
Could you put a Signaltap probe on the Avalon Stream going to the TSE, to check what's going in and how much pagding you have in front of the packet?
I have similar problem. I observe UDP data in wireshark with additional 2 byte data (00 00) at the beginning of payload inserted by Alignment pad inserter component. But when I remove this alignment pad inserter component, It's no more recognized as a UDP data.
Is there any solution to this problem?
