12604 Discussions
Terasic ETHERNET-HSMC Card and Arrow SoCkit
Hi all,
I have a Arrow SoCkit and a Terasic ETHERNET-HSMC Card. I'm trying to use this daughter card whit the SoCkit but seem to be incompatibles.
For example the NET1_RX_D6 of the ETHERNET-HSMC Card (that is an input pin) is assigned to HSMC Pin 59, this pin in the Arrow SoCkit is connected to the FPGA pin G7 that is a dedicate OUTPUT pin!!!
Can anyone help me?
Pin G7 is a dedicated output only if used as part of a differential pair. If not used as a differential pair it can be used as a user I/O pin. Look at the pin connection guidelines for Cyclone V:
http://www.altera.com/literature/dp/cyclone-v/pcg-01014.pdf
