12604 Discussions
The BSP Editor unable to edit or create the HPS BSP
Hi, All:
I create a QSys system for my Cyclone V SoC chip, and according to the manual, I need to create the BSP for the chips then I can run my QSys system correctly.
According to the manual, I open the Embedded Command Shell.bat in Administrator, and enter
bsp-editor &
to open the BSP Editor.
But in the BSP Editor, I see the menu File -> New HPS BSP... is gray, I can not click on it.
I try to open a example bsp file in the CD of my development board, the BSP Editor reported several errors, and can not open them.
The errors like:
Available BSP type values for the --type argument are: BSP type "spl" unknown NullPointerException
I see that is a error due to the BSP Editor can not find the HPS BSP Informations.
I try to reinstall the software, even install in my virtual machine, but all of them are got same erros.
What's wrong with my approach?
Thank you very much.
Dmitri Abramovic
Hi All,
I solve this problem by reinstall the Quartus and SoC Suite in a Directory that does NOT CONTAIN SPACES.
Originally I installed it in H:\Quartus XVII\SoC Suite, it doesn't work,
now I install it in H:\Quartus\SoC, it works fine.
Dmitri Abramovic
