12600 Discussions
The Code/s Which Will Set the Internal Osc. to 4MHz for PIC16F628
Good day,
Could you please help me with the code/s which will set the internal Osc. to 4MHz for a PIC16F628.
I used the following for a external Crystal for 4MHz.
Device = 16F628( pic16f628 pdf (http://www.kynix.com/uploadfiles/pdf8798/pic16f628-042fp_200619.pdf) )
Xtal = 4
All_Digital = True
Dim D As Word
Int: TRISB = %00000000
PORTB = 0
D = 150
Main: High PORTB.0
DelayMS D
Low PORTB.0
GoTo Main
Now I would like to use the internal Osc. to do the same as the external Osc.
Thanks very much
Hello Whatry,
Your question is even more likely to get answered properly on the MICROCHIP forum.
This forum is for INTEL/ALTERA products, MICROCHIP is another company.
http://www.microchip.com/forums/ is the MICROCHIP forum.
Johi.
