I am starting a bare-metal development on DE0-Nano-SoC_Computer. I use the development tool: DS5 AE. I begin by a timer program found in the document “DE0-Nano-SoC Computer System with ARM Cortex-A9”: equ bit_24_pattern, 0x01000000/* this program provides a simple example of code for the arm a9. it:
* 1. starts the arm a9 private timer
* 2. loops forever, toggling the hps green light ledg when the timer expires
.text
.global _start
_start:
ldr r0, =0xff709000 // gpio1 base address
ldr r1, =0xfffec600 // mpcore private timer base address
ldr r2, =bit_24_pattern // value to turn on the hps green light ledg
str r2, [r0,# 0x4] // write to the data direction register to set
// bit 24 (ledg) of gpio1 to be an output
ldr r3, =200000000 // timeout = 1/(200 mhz) x 200×10∧6 = 1 sec
str r3, [r1] // write to timer load register
mov r3,# 0b011 // set bits: mode = 1 (auto), enable = 1
str r3, [r1,# 0x8] // write to timer control register
loop:
str r2, [r0] // turn on/off ledg
wait: ldr r3, [r1,# 0xc] // read timer status
cmp r3,# 0
beq wait // wait for timer to expire
str r3, [r1,# 0xc] // reset timer flag bit
eor r2, r2,# bit_24_pattern // toggle ledg value
b loop
.end
The HPS GPIO registers are unavailable, it’s impossible to see the values in the registers tab of DS5. The values of addresses 0xFF709000 are 0x00000000 in the memory tab of DS5. Is it necessary to initialize the GPIO before launching the program? Thanks for your help. Jerome
