12604 Discussions
The developer has enough knowledge...?
How does this guy reach the top of 'PLTresolver' if the PLT entries are more than 2729?
/* PLT implementation for position-independent code. */
static const bfd_vma nios2_so_plt_entry[] = { /* .PLTn */
0x03c00034, /* movhi r15, %hiadj(index * 4) */
0x7bc00004, /* addi r15, r15, %lo(index * 4) */
0x00000006 /* br .PLTresolve */
static const bfd_vma nios2_so_plt0_entry[] = { /* .PLTresolve */
0x001ce03a, /* nextpc r14 */
0x03400034, /* movhi r13, %hiadj(_GLOBAL_OFFSET_TABLE_) */
0x6b9b883a, /* add r13, r13, r14 */
0x6b800017, /* ldw r14, %lo(_GLOBAL_OFFSET_TABLE_+4)(r13) */
0x6b400017, /* ldw r13, %lo(_GLOBAL_OFFSET_TABLE_+8)(r13) */
0x6800683a /* jmp r13 */
The instruction 'br' can only do the indirect jump within 16 bits.
Kazu
