The problem of the DasUBoot !
http://www.alterawiki.com/wiki/dasuboot
4. configure and build,
make clean
make my_nios2_config
make
I've set,
"export CROSS_COMPILE=nios2-linux-uclibc- "
In u-boot dir, put my_nios2.h in include/configs/, put my_nios2_fpga.h in board/altera/nios2-generic/. Then add an entry my_nios2 to the NIOS2_GENERIC list,like this:
# include "../board/altera/nios2-generic/my_nios2_fpga.h" /* fpga parameters */
# define CONFIG_BOARD_NAME "my_nios2" /* custom board name */
Why does the command not work ?
[root@localhost u-boot]# make clean
[root@localhost u-boot]# make my_nios2_config
make: *** No rule to make target `my_nios2_config'. Stop.
make: *** No rule to make target `my_nios2'. Stop.
THANKS !
What does these mean ?
1. add an target entry to the file boards.cfg in u-boot directory after the line containing nios2-generic, like this my_nios2,
nios2-generic nios2 nios2 nios2-generic altera
my_nios2 nios2 nios2 nios2-generic altera
Means to set the new file named boards.cfg,and modify the info of the "
my_nios2 nios2 nios2 nios2-generic altera"
into it????????????????????????????
http://www.alterawiki.com/wiki/guide_to_3c120_with_u-boot
in u-boot dir, put 3C120.h in include/configs/, put 3c120_fpga.h in board/altera/nios2-generic/. Then add an entry 3C120 to the NIOS2_GENERIC list in Makefile.
make 3C120_config
http://www.alterawiki.com/wiki/extrem_guide_to_kill_neek_with_u-boot
in u-boot dir, put NEEK.h in include/configs/, put neek_ocm_spi_mmu.h in board/altera/nios2-generic/. Then add an entry NEEK to the NIOS2_GENERIC list in Makefile.
make NEEK_config
http://www.alterawiki.com/wiki/guide_to_2c35_cf_with_u-boot
in u-boot dir, put 2C35.h in include/configs/, put 2c35_cf.h in board/altera/nios2-generic/. Then add an entry 2C35 to the NIOS2_GENERIC list in Makefile.
make 2C35_config
Why did I do this above,it show me error ?
Means to add the "my_nios2" into all the file including the "nios2-generic" in the u-boot folder~!
MAKE IT!gaga~
