12603 Discussions
Transceiver toolkits example modification
Hello
I want to modify (sv_1ch_40b_10312mbps) trasciever toolkits example so that send GOLD codes sequence instead to PRBS .
I will use GOLD codes sequence to encode random data at transmiter side and decode it at reciever side and then check if there is error occurred.
I have tried to modify "altera_avalon_data_pattern_generator.v” file and Compile the project, program the device, and run the Transceiver Toolkit,When i run link tests, channel color highlights yellow .
Moreover , I have tried to make small modification in the design , for example in the below part of "altera_avalon_data_pattern_generator.v” file i replace the
prbs[0] <= prbs[0] ^ prbs[3] ^ prbs[4] ^ prbs[6] ;
instead
prbs[0] <= prbs[0] ^ prbs[3] ^ prbs[4] ^ prbs[5] ;
unfortunately , i have gotten the same problem .
part from "altera_avalon_data_pattern_generator.v” file
if (ST_DATA_W == 32) begin
always @(posedge aso_clk or posedge reset) begin
if (reset) begin
prbs <= ~0;
end else begin
if (state == ST_IDLE) begin
prbs <= ~0;
end
if (advance_prbs) begin
case (pattern_select)
SEL_PRBS_7 : begin
// PRBS 2^7-1 (T[7,6]) (parallel 40-bit serializer)
prbs[1] <= prbs[1] ^ prbs[4] ^ prbs[5] ^ prbs[6] ;
prbs[2] <= prbs[0] ^ prbs[2] ^ prbs[5] ;
Can you please help me to solve my problem?
Thanks in advance.
Hello
I’m interesting with this example, the problem that I need to change the generator and checker and lets the other part of the design.
Please if there are some one that he have a tutorial or an example to do something like this, it will be appreciate.
Thank you for your cooperation.
