12453 Discussions
Transferring files to Linux target via JTAG
I'm trying to transfer files to uCLinux running on a NIOS II CPU with MMU. The problem is that the design has no ethernet controller. Is there a way to transfer files to the target Linux via JTAG? Which software would I need on the target and on the host?
--- Quote Start ---
--- Quote End ---
Maybe you want to transfer binary files, and if you can use JTAG-UART, then it is one method to use xmodem protocol.
http://www.menie.org/georges/embedded/
In your PC side, maybe you must use 'nios2-terminl'. See also
http://www.markuspage.com/markus/images/nios2-terminal-pipe.pdf
http://www.codeproject.com/articles/5531/redirecting-an-arbitrary-console-s-input-output
etc.
Kazu
