12589 Discussions
Trouble building project with Cygwin
I am trying to automate my build process, so I installed Cygwin to build my NIOS-II software projects. I am able to build my project with the NIOS II software build tools for Eclipse GUI, but I run into a problem when build from the command line.
I believe I have added the proper directories to my search path, but when I make, I still get a command not found error. I have included the error message below. Any help with solving this will be very much appreciated.
Nsatyana
$ make
Info: Building ../hello_0_bsp/
C:/altera/11.0/nios2eds/bin/gnu/H-i686-mingw32/bin/make --no-print-directory -C
../hello_0_bsp/
[BSP build complete]
Info: Linking hello_0.elf
nios2-elf-g++ -T'../hello_0_bsp//linker.x' -msys-crt0='../hello_0_bsp//obj/HAL/
src/crt0.o' -msys-lib=hal_bsp -L../hello_0_bsp/ -Wl,-Map=hello_0.map -O0 -g
-Wall -EL -mno-hw-div -mhw-mul -mno-hw-mulx -o hello_0.elf obj/hello_world.o
-lm
nios2-elf-insert hello_0.elf --thread_model hal --cpu_name cpu --simulation_enab
led false --id 0 --sidp 0x10022c90 --timestamp 1319134118 --stderr_dev jtag_uart
--stdin_dev jtag_uart --stdout_dev jtag_uart --sopc_system_name cycloneIII_3c12
0_dev_niosII_standard_sopc --quartus_project_dir "c:/altera/11.0/kits/CycloneIII
_3C120_FPGA/examples/NS_cycloneIII_3c120_dev_niosII_standard" --jdi C:/altera/11
.0/kits/CycloneIII_3C120_FPGA/examples/NS_cycloneIII_3c120_dev_niosII_standard/c
ycloneIII_3c120_dev_niosII_standard.jdi
C:\altera\11.0\nios2eds\bin\nios2-stackreport: line 6: /cygdrive/c/altera/11.0/n
/sh_pl.sh: No such file or directory
C:\altera\11.0\nios2eds\bin\nios2-stackreport: line 7: $'\r': command not found
make: *** [hello_0.elf] Error 127
make: *** Deleting file `hello_0.elf'
I'd look at the nios2-stackreport file, I think it is being executed as a shell script - but may be some binary file.
OTOH I'm not at all clear why Altera need to use java to hack elf binaries!
nios2stackreport is a bash script and its contents are as follows:# !/bin/bash
FILEPATH=${0//\\/\/}
_this_script=$(cd ${FILEPATH%[\\/]*} && echo $(pwd 2>/dev/null)/${FILEPATH##*/})
_this_script_dir=$(dirname ${_this_script})
export SOPC_KIT_NIOS2=${_this_script_dir/\/bin}
. "${_this_script_dir}/sh_pl.sh" $@
I was having trouble with the last line. sh_pl.sh was not being properly called, so I located sh_pl.sh on my system and called it explicitly using its absolute path. and i got the following error message:
$ make
../hello_0_bsp/
Info: Compiling hello_world.c to obj/hello_world.o
nios2-elf-gcc -xc -MP -MMD -c -I../hello_0_bsp//drivers/inc -I../hello_0_bsp//HA
L/inc -I../hello_0_bsp/ -I../hello_0_bsp//drivers/inc -DSYSTEM_BUS_WIDTH=32 -pi
pe -D__hal__ -DALT_NO_INSTRUCTION_EMULATION -DALTERA_TRIPLE_SPEED_MAC -DALT_SING
LE_THREADED -O0 -g -Wall -EL -mno-hw-div -mhw-mul -mno-hw-mulx -o obj/hell
o_world.o hello_world.c
-lm
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LC_ALL = (unset),
LANG = "C.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Can't locate sh_launch.pm in @INC (@INC contains: /cygdrive/c/altera/11.0/nios2e
/bin C:/PROGRA~1/MKS/Toolkit/etc/perl/lib C:/PROGRA~1/MKS/Toolkit/etc/perl/lib C
:/PROGRA~1/MKS/Toolkit/etc/perl/lib/site_perl C:/PROGRA~1/MKS/Toolkit/reskit/etc
/perl/lib/i386 .) at C:\altera\11.0\nios2eds\bin\nios2-stackreport.pl line 1.
BEGIN failed--compilation aborted at C:\altera\11.0\nios2eds\bin\nios2-stackrepo
rt.pl line 1.
make: *** [hello_0.elf] Error 2
I have no idea how to begin debugging this. I just commented out the last line from nios2-stackreport and the build completes succesfully. I know this work around is going to come back to haunt me later, but it will do for now. Here are the contents of sh_pl.sh
# !/bin/sh
PERL5LIB=`cygpath -u "$SOPC_KIT_NIOS2/bin"` perl "${SH_PL:-$0.pl}" $@
Hopefully this step is not too important, and leaving it out won't affect my build.
Some observations - not that they probably affect your problem!
Those scripts probably shouldn't be assuming that $0 contains the absolute path of the script. If a unix kernel processes the# ! it has to set $0 to something the process can open to get the script (which is why it is usually the full path), but the actual contents aren't well defined - it can be /dev/fd/n.
The $@ should be "$@" in both scripts - otherwise the parameters are subject to field splitting (bad news if there are any embedded spaces).
Might be worth setting LANG=C before running perl.
