Hello, guys!
I am a beginner on learning FPGA, recently my professor ask my to transmit the data from the FPGA to a LAN or internet via ethernet, and I am deeply troubled by this First, I try to follow the tutorial on "Using Triple-Speed Ethernet on DE2-115 Boards" However I found out that it also needs to use NIOS II, however, I already use it for computation purpose before. I want the data transmission and the computation to process at the same time. Is there any way that I can do this let NIOS execute two different codes at the same time? Also, I found out that instead of storing the code in SDRAM, the tutorial store the code in "Altera Monitor Program" - on chip memory, will it infer any conflicts? I also thought about build two nios on the system, is this possible? Thanks!Link Copied
