UART Core with CTS/RTS
In a working design I configured my UART core so that it uses CTS/RTS.
But I do not get a simple design running that shall only send integers from a Windws hyperterminal to via the Nios core and back to the hyperterminal.
I have double-checked that the CTS/RTS-pins are connected as stated in the Stratix II development board, which I am using. Also I have the same baud rate (115200). On the hyperterminal I have selected "Flow Control: Hardware". However, nothing happens.
Can somebody help?
Below is the code of my program, which works without CTS/RTS - Hardware Flow Control.
# include <stdio.h># include "system.h"# include "alt_types.h"# include <time.h># include <sys/alt_timestamp.h>
int main()
int x;
FILE* infile;
FILE* outfile;
infile = fopen("/dev/uart1", "r");
outfile = fopen("/dev/uart1", "w");
printf("System ready!\n");
fprintf(outfile, "System ready!\n\r");
while(1)
// fprintf(outfile,"New Number: ");
if (fscanf(infile, "%d", &x))
fprintf(outfile, "Received: %d\r\n", x);
printf("Received: %d\r\n", x);
return 0;
One deviec shall not be open twice before it was closed.
Maybe,
io_file = fopen("/dev/uart1", "rw");
I just reply it without confirming anything, so please look up some DATASHEET.
use a terminal program (e.g. BRAY&#39;s TERMINAL) where you can switch on/off
RTS and where you can see the state of CTS.
see file altera_avalon_uart_regs.h
you can check CTS at nios side with...
uartstatus=IORD_ALTERA_AVALON_UART_STATUS(UART_1_BASE);
if(uartstatus&ALTERA_AVALON_UART_STATUS_CTS_MSK) {
... // cts is set (low)
you can set RTS with ...
ctrl=IORD_ALTERA_AVALON_UART_CONTROL(UART_1_BASE);
ctrl|=ALTERA_AVALON_UART_CONTROL_RTS_MSK;
// ctrl&=~ALTERA_AVALON_UART_CONTROL_RTS_MSK; // to clear
IOWR_ALTERA_AVALON_UART_CONTROL(UART_1_BASE,ctrl)
if CTS is not set, the fast driver will not send any byte,
RTS is ignored by the driver, you have to handle it by yourself.
Sorry there was something wrong in my last answer,
the commands to set/reset RTS conflict with the fast
driver of the uart.
After checking the documetation,
There is no information how RTS and CTS is used by the HAL !
There is no description, which flags of the termios structure
are supported.
How can I set/reset RTS from application ???
Anyway Fischer,
thanks for your reply that helped me to find Bray&#39;s terminal. At least I no now that my NiosCore works with "clean" CTS/RTS mode.
But in many applications (hyperterminal, matlab) there is the option "FlowControl = Hardware" and this seems not to be clean CTS/RTS, because the communication is simply dying...
Alchemist
P.S: It seems, Altera tries to hide "unimportant details" from the user. However, sometimes some of these details are needed...
I learned a new term reading this post so now I&#39;m curious..... what is "clean" CTS/RTS mode? (I know flow control but what do you mean by "clean"???). By clean if you mean a clean signal ........ RS232 has never been known to be "clean".
make sure you set the tx fifo in the com port properties to 1. Do this through control panel - system - device manager.
This is because, when it&#39;s more than 1 (typically 14/16), the PC continues to send data after you raise CTS. It continues until its FIFO is emptied. Thus you would experience Rx overruns on your embedded device.
--- Quote Start ---
originally posted by badomen@Jun 23 2005, 11:12 AM
i learned a new term reading this post so now i&#39;m curious..... what is "clean" cts/rts mode?  (i know flow control but what do you mean by "clean"???).  by clean if you mean a clean signal ........ rs232 has never been known to be "clean".
--- Quote End ---
Hej BadOmen,
with "clean" I meant that only the CTS/RTS and TxD and RxD are used. It is maybe a strange and unofficial term, but since i now have problems with tools like "Hyperterminal" and also "Matlab", where you just specify "FlowControl = Hardware" and do not really know, which pins take part in the communication, I think the term is justified... (When assigning CTS/RTS in a more advanced terminal program, the communication works).
By the way, maybe someone has a experiences with Matlab and CTS/RTS-communication with Nios. I read the Matlab documentation, but did not get it working.
Here are my matlab commands (but I tried other as well):
>> s2 = serial(&#39;COM2&#39;);
>> set(s2, &#39;BaudRate&#39;, 115200);
>> set(s2, &#39;FlowControl&#39;, &#39;hardware&#39;);
>> set(s2, &#39;DataTerminalReady&#39;, &#39;off&#39;);
>> fopen(s2)
>> fprintf(s2, &#39;%d&#39;, 3);
Matlab "freezes" after execution of these commands...
So, if somebody has a good idea, it would be great...
if you use RTS&CTS Handshake and you set hyperterminal to flowcontrol,
perhaps it also wants to handle DTR/DSR/CD Signals.
assuming 9 PIN SUB-D
at the PC side, make a bridge between PINS 4 -> 6+1, so the PC
sets DATA TERMINAL READY(PIN4) and gets back DATA SET READY(PIN6) + CARRIER DETECT(PIN1)
see also http://www.hardwarebook.net/cable/serial/n...lmodem9to9.html (http://www.hardwarebook.net/cable/serial/nullmodem9to9.html)
Ok I find THE solution: RST/CTS flow control works well. This my code:
int main()
char* msg = "Detected the character &#39;t&#39;.\n";
FILE* fp;
char prompt = 0;
fp = fopen("/dev/uart", "r+");
unsigned int uart_status;
unsigned int uart_ctrl;
if(fp)
while(prompt != &#39;v&#39;)
prompt = getc(fp);
if(prompt == &#39;t&#39;)
fwrite(msg, strlen(msg), 1, fp);
fprintf(fp, "Closing the UART file.\n");
fclose(fp);
return(0);
This code works under Hyper Terminal with "hardware" flow control.
I found the error. It iwas an Altera error.
You just have to change :
CTS: PIN L15 (instead of PIN K15)
RTS: PIN K15 (instead of PIN L15)
for the Altera DSP Stratix II Evaluation Board.
In your code, what do you mean by "&#39" ?
and how are you checking for an incoming RTS and setting ur own RTS(sending CTS) signal?
