UART with FIFO Buffer
Need to use UART with FIFO Buffer in SOPC Builder Nios II System:
1> The UART RS232 available in SOPC are without FIFO is it possible to add FIFO by modifying the same UART core
2> If not is there any other SOPC ready UART_FIFO core available as free IP
3> If not is it possible to get estimate of
- LE utilization without Modem Control logic
- Is it necessary to write device driver for the same
- Apprx how much design time it will take to
design HDL UART, device driver for a single person?
Please advice asap. running short of time.
Thanks in Advance
--- Quote Start ---
originally posted by rau@Oct 24 2005, 09:16 AM
need to use uart with fifo buffer in sopc builder nios ii system:
1> the uart rs232 available in sopc are without fifo is it possible to add fifo by modifying the same uart core
2> if not is there any other sopc ready uart_fifo core available as free ip
3> if not is it possible to get estimate of
  - le utilization without modem control logic
  - is it necessary to write device driver for the same
  - apprx how much design time it will take to
    design hdl uart, device driver for a single person?
please advice asap. running short of time.
thanks in advance
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10542)
--- quote end ---
--- Quote End ---
Hi
i think in sopc builder when we instantiate uart
we get tab which asks for fifo size as it is in built.
but i don&#39;t understand why u need another fifo
for a uart.anyway i don&#39;t think it may be required.
prasad
--- Quote Start ---
originally posted by rau+oct 24 2005, 09:16 am--><div class='quotetop'>quote (rau @ oct 24 2005, 09:16 am)</div>
--- quote start ---
1> the uart rs232 available in sopc are without fifo is it possible to add fifo by modifying the same uart core[/b]
--- quote end ---
that uart&#39;s code is generated on-the-fly by the sopc builder, so you could modify it, but it would be tricky, and you&#39;d have to figure out a way to keep your changes from being overwritten when the sopc gets regenerated. good luck there.
--- quote start ---
--- quote end ---
not that i&#39;m aware of. there are free cores, and cores that integrate with sopc builder, but not both.
--- quote start ---
--- quote end ---
usually the ip data sheet gives some clue to this.
--- quote start ---
--- quote end ---
maybe. assume it&#39;s going to need a driver unless you can find one out there already.
--- quote start ---
--- quote end ---
a while. this depends on many unmeasurable factors, so i couldn&#39;t give you a number. but it won&#39;t be easy.
<!--quotebegin-prasad_forums@Oct 26 2005, 01:03 AM
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10579)
--- quote end ---
--- Quote End ---
Really? I&#39;ve never seen that. However, I&#39;ve only used the Nios2 Altera UART, not any other core. Maybe you&#39;re thinking of the JTAG UART?
Hallo rau,
there is a free UART16550 core from OpenCores that can simply be implemented in a NIOS design and it is also not that problem to implement it into the SOPC Builder. All you have to do is to import the top level design file into the SOPC builder using the "Create new component feature" or to write your own bus wrapper to connect the WISHBONE bus to the AVALON.
You will find this core here:
opencores uart16550 (http://www.opencores.com/projects.cgi/web/uart16550/overview
More work has to be done to write some driver software for it. The register structure of this UART is also really simple so that it should only take a short time to bring something up to work.
Best regards...
Mschulz.
There is a uart with fifo which Altera sent me when I was having troubles with the standard uart speed. The file is ACF2002.zip which I am sure you can ask for from the service request people.
You need unzip it and add this whole directory to this location: <NiosII Installation Path>/components/. Then you can reopen the SOPC Builder to add this UART with fifo.
It comes up as "cal uart".
Good luck
Ed
praveenkumar
please send the file to  mail @praveentatikonda2155@gmail.com
dear Edmund,
Could you give the file ,thanks ,my email:nwpu_zhfeng@126.com
Thanks for all the i/ps.
On my way to design UART with FIFO which will be included in Nios sys.
In case of any difficulties/problems will keep coming back
Thanks and Regards
--- Quote Start ---
originally posted by mike desimone+oct 27 2005, 12:44 am--><div class='quotetop'>quote (mike desimone @ oct 27 2005, 12:44 am)</div>
--- quote start ---
--- quote start ---
--- quote end ---
--- quote start ---
--- quote end ---
--- quote start ---
--- quote end ---
--- quote start ---
--- quote end ---
--- quote start ---
--- quote end ---
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10611)</div>
[/b]
--- Quote End ---
dear Edmund,
Could you give the file ,thanks you very much!
my email: wfeiwu@21cn.com
feiwu
--- Quote Start ---
originally posted by feiwu@Nov 23 2005, 01:19 PM
dear edmund,
could you give the file ,thanks you very much!
best regards,
feiwu
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11105)
--- quote end ---
--- Quote End ---
I have finished designing the UART having with FIFO without FIFO mode.
the components/entities are as follows:
Reciver State Machines - 1.write cycle
2.read cycle
Receiver Shift Register, Receiver FIFO and data register
Transmitter State Machines - 1.Write cycle for Data register and FIFO + Read cycle
for Data
2.read cycle for FIFO
3.shifting data out
Transmitter FIFO and data register, Receiver shift register
Register Bank
Register select logic
and Baud rate generator
I need a clarification:
The Baud rate generator is generating a clock from the system clock.
I am using baud clock for
Transmitter shift register
and transmitter state machine 3 for shifting data out
rest all transmitter aoperation is on system clock i.e. TXFIFO uses single clock
In RX logic
baud clock is used for RXshift register to shift in the data and for the state machine that controls shifting in the data and writing to FIFO/data register
ie. RX state machine 1
the RXFIFO and receiver state machine controlling the read cycle work on system clock.
I need confirmation that ifthe way I am using baud clock and the system clock is correct?
regards
Edmund
I also have the same problem. Could you please email it to victors@mweb.co.za
Hallo Edmund,
is it also possible, that I can get the ZIP file for the FIFO UART?
Thanks, M.Schulz.
Dear everyone,
Who has used the CAL_UART successfully?
Could you please tell me how to use it in uClinux ?
Fei Wu
Hi Edmund,
I have the same problem. Could you pls email the file to...
hootsmon1 at hotmail dot com
**edited ** Got it now, thanks all
I have the same problem. Could you pls email the file to me: r_wa@sina.com
thanks.
Hi all,
for information, the cal_uart is not performant unless you make some modifications. Actually, it works correctly in poll mode, not with interrupts. The reason for this is that the interrupts are not generated correctly, and can freeze the system (I use it mainly under uClinux, I don&#39;t know the HAL driver very well).
A first fix to this is to change
<cal_uart>/uart_pm.pl:l1933:rx_char_ready to rx_not_empty
This will generate the IRQ properly (regarding to avalon spec), but will not take advantage of the FIFO (IRQ when 1 byte is in the FIFO, which is not optimized). I changed the VHDL to take full advantage of the FIFO, i.e. generate IRQ when FIFO is half full, or every xx ms if a char is present in FIFO.
All this is explained in the "cal_uart(with fifo) + NIOSserial.c" thread in uClinux forum.
Hope this helps,
Pierre-Olivier
These work great! and integrate with SOPC builder very easily (instructions included work great!).
http://forum.niosforum.com/forum/index.php?showtopic=4120 (http://forum.niosforum.com/forum/index.php?showtopic=4120
I have tested it out and find no problems.
Dear Edmund
Could you give the file ^^
My Email pearlt@chol.com
thanks for your help^^
Hi,pearlt.
I read about the UART with FIFO you requested to Edmund.
Did you receive that? Can you send me too?
My email is
tonelli.paolo@gmail.com
Many thanks in advance.
Oh,many thanks Slaker.Now,it&#39;s ok.
I hope this will be easy to use as get it through your link http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
