Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
UDP Socket in Niche Stack for Windows
Slacker has posted example for linux or unix operating system, how to make it work in windows operating system? The compiler is run on windows. Thanks.
Highlighted
Re: UDP Socket in Niche Stack for Windows
The first post by "Nit", here (http://www.gamedev.net/topic/383926-using-udp-in-winsock-tutorials/), looks to be a decent reference for sending/receiving UDP sockets on Windows.
I haven't looked to see what the deltas are as I try to avoid this level of programming in Windows...
Cheers,
slacker
