USB device!
I have a usb flash disk, I want to using it on my board, I choose USB Mass storage and SCSI disk and ISA116X driver support in menuconfig. Start uClinux on NIOS II SDK shell, using dmesg, I got these message:
# dmesg
Linux version 2.6.11-uc0 (root@localhost.localdomain) (gcc version 3.4.6)# 11 Sa
t Apr 15 17:52:30 CST 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 008F0000
On node 0 totalpages: 2048
DMA zone: 2048 pages, LIFO batch:1
Normal zone: 0 pages, LIFO batch:1
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6188k/8192k RAM, 0k/0k ROM (1334k kernel code, 551k data)
Calibrating delay loop... 24.72 BogoMIPS (lpj=123648)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler deadline registered
dmfe_probe:eth0, 50000 Khz Nios
<DM9000> eth0 I/O: 80900090, VID: 90000a46
ADDR: 00:07:ed:00:00:00
dmfe_probe:eth1, 50000 Khz Nios
Linux video capture interface: v1.00
116x: driver isp116x-hcd, 08 Apr 2005
116x: ISP116x Host Controller, irq 4
isp116x-hcd isp116x-hcd: new USB bus registered, assigned bus number 1
116x: Invalid chip ID 3630
isp116x-hcd isp116x-hcd: USB bus 1 deregistered
116x: init error, -19
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
NET: Registered protocol family 17
Freeing unused kernel memory: 436k freed (0x15e000 - 0x1ca000)#
I plug my usb flash disk in my board usb host port, there is no message appear!
How could I to find the usb disk?
the usb chip in DE2 is not isp116x, it is isp1362.
reply in new thread,
http://forum.niosforum.com/forum/index.php?showtopic=3707 (http://forum.niosforum.com/forum/index.php?showtopic=3707)
Thanks for your help, I will try it. If have done, I will tell you!
hi all
I have the same problem,too.
this is my booting messages....................
uClinux/Nios II
Built 1 zonelists
Memory available: 5904k/8192k RAM, 0k/0k ROM (1612k kernel code, 580k data)
io scheduler deadline registered (default)
usbmon: debugfs is not available
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362_hc_reset:
Clock not ready after 20ms
isp1362-hcd isp1362-hcd: can&#39;t reset
init error, -19
i2c /dev entries driver
IP route cache hash table entries: 128 (order: -3, 512 bytes)
TCP established hash table entries: 512 (order: -1, 2048 bytes)
TCP reno registered
TCP bic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
Freeing unused kernel memory: 448k freed (0x1a6000 - 0x215000)
init started: BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) multi-call binary
BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) Built-in shell (msh)
Enter &#39;help&#39; for a list of built-in commands.
# cd /proc# more mounts
rootfs / rootfs rw 0 0
proc /proc proc rw 0 0
sysfs /sys sysfs rw 0 0# mount -t vft /dev/hda /mount
mount: Mounting /dev/hda on /mount failed: No such file or directory#
when I plug my usb disk on my uClinux then no response .
so , i can&#39;t mount my usb flash disk.......... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
thank in advance!
jay
The isp1362 is not working. You have to check the regs and irq of the chip. Study the regs map from the data sheet of the chip.
We will debug the driver code.
First, you should setup source code version control with subversion.
We will have to update or revert the code during debug.
# remove old linux source rm -rf ~/linux-2.6.x ~/mysvn/2.6.11-uc0# kernel 2.6.11-uc0 source ported by microtronix cp -a ~/download/mx140/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~ cd ~/linux-2.6.x patch -p0 <~/download/kernel.diff cp ~/download/kernel.config ~/linux-2.6.x/.config cd ~ mkdir mysvn# setup svn svnadmin create mysvn/2.6.11-uc0 svn import linux-2.6.x file:///home/jack/mysvn/2.6.11-uc0/linux-2.6.x -m="initial" rm -rf ~/linux-2.6.x svn co file:///home/jack/mysvn/2.6.11-uc0/linux-2.6.x patch -p0 <~/download/isp1362.diff svn add drivers/usb/host/isp1362.h drivers/usb/host/isp1362-hcd.c include/linux/usb_isp1362.h svn commit -m="add isp1362 hcd"
Then in function isp1362_hc_reset() of ~/linux-2.6.x/drivers/usb/host/isp1362_hcd.c
add some printk() to display the io ports of data, addr and irq.
add a dump_regs() to display the regs.
try some write / read compare to the regs.
add some dump_regs during the clock test.
We have to make sure the chip can be accessed by the driver correctly.
Check the clock, data... etc with a scope.
Check irq pin during the clokc test.
hi hippo
Before i was uesd the patch "isp1362-nios2-01.diff" and compiled ok.
now,i am using patch "isp1362" and complie ok,but i can&#39;t find the "isp1362-hcd.o" in ~/linux2.6.x/drivers/usb/host dir.
i find the "(CONFIG_USB_ISP362X_HCD)" at line 14 in ~/linux2.6.x/drivers/usb/makefile and replace it to "(CONFIG_USB_ISP1362_HCD)"..
final , when i have rebuild kernel then occur error messages........
CHK include/asm-nios2nommu/asm-offsets.h
CHK include/linux/compile.h
CHK usr/initramfs_list
CC drivers/usb/host/isp1362-hcd.o
drivers/usb/host/isp1362-hcd.c:1293: error: syntax error before "gfp_t"
drivers/usb/host/isp1362-hcd.c:1294: warning: function declaration isn&#39;t a prototype
drivers/usb/host/isp1362-hcd.c: In function `isp1362_urb_enqueue&#39;:
drivers/usb/host/isp1362-hcd.c:1295: error: `hcd&#39; undeclared (first use in this function)
drivers/usb/host/isp1362-hcd.c:1295: error: (Each undeclared identifier is reported only once
drivers/usb/host/isp1362-hcd.c:1295: error: for each function it appears in.)
drivers/usb/host/isp1362-hcd.c:1296: error: `urb&#39; undeclared (first use in this function)
drivers/usb/host/isp1362-hcd.c:1333: error: `hep&#39; undeclared (first use in this function)
drivers/usb/host/isp1362-hcd.c:1334: error: `mem_flags&#39; undeclared (first use in this function)
drivers/usb/host/isp1362-hcd.c:1341: warning: implicit declaration of function `HC_IS_RUNNING&#39;
drivers/usb/host/isp1362-hcd.c: In function `isp1362_mem_config&#39;:
drivers/usb/host/isp1362-hcd.c:2415: warning: int format, long unsigned int arg (arg 5)
drivers/usb/host/isp1362-hcd.c:2418: warning: int format, long unsigned int arg (arg 5)
drivers/usb/host/isp1362-hcd.c: In function `isp1362_hc_start&#39;:
drivers/usb/host/isp1362-hcd.c:2776: error: `HC_STATE_RUNNING&#39; undeclared (first use in this function)
drivers/usb/host/isp1362-hcd.c: At top level:
drivers/usb/host/isp1362-hcd.c:2818: error: unknown field `bus_suspend&#39; specified in initializer
drivers/usb/host/isp1362-hcd.c:2819: error: unknown field `bus_resume&#39; specified in initializer
drivers/usb/host/isp1362-hcd.c: In function `isp1362_remove&#39;:
drivers/usb/host/isp1362-hcd.c:2828: warning: implicit declaration of function `platform_get_drvdata&#39;
drivers/usb/host/isp1362-hcd.c:2828: warning: initialization makes pointer from integer without a cast
drivers/usb/host/isp1362-hcd.c:2834: warning: implicit declaration of function `usb_remove_hcd&#39;
drivers/usb/host/isp1362-hcd.c: In function `isp1362_probe&#39;:
drivers/usb/host/isp1362-hcd.c:2927: error: too many arguments to function `usb_create_hcd&#39;
drivers/usb/host/isp1362-hcd.c:2932: error: structure has no member named `rsrc_start&#39;
drivers/usb/host/isp1362-hcd.c:2958: warning: implicit declaration of function `usb_add_hcd&#39;
drivers/usb/host/isp1362-hcd.c:3043: error: variable `isp1362_driver&#39; has initializer but incomplete type
drivers/usb/host/isp1362-hcd.c:3044: error: unknown field `probe&#39; specified in initializer
drivers/usb/host/isp1362-hcd.c:3044: warning: excess elements in struct initializer
drivers/usb/host/isp1362-hcd.c:3044: warning: (near initialization for `isp1362_driver&#39;)
drivers/usb/host/isp1362-hcd.c:3045: error: unknown field `remove&#39; specified in initializer
drivers/usb/host/isp1362-hcd.c:3045: warning: excess elements in struct initializer
drivers/usb/host/isp1362-hcd.c:3045: warning: (near initialization for `isp1362_driver&#39;)
drivers/usb/host/isp1362-hcd.c:3047: error: unknown field `suspend&#39; specified in initializer
drivers/usb/host/isp1362-hcd.c:3047: warning: excess elements in struct initializer
drivers/usb/host/isp1362-hcd.c:3047: warning: (near initialization for `isp1362_driver&#39;)
drivers/usb/host/isp1362-hcd.c:3048: error: unknown field `resume&#39; specified in initializer
drivers/usb/host/isp1362-hcd.c:3048: warning: excess elements in struct initializer
drivers/usb/host/isp1362-hcd.c:3048: warning: (near initialization for `isp1362_driver&#39;)
drivers/usb/host/isp1362-hcd.c:3049: error: unknown field `driver&#39; specified in initializer
drivers/usb/host/isp1362-hcd.c:3049: error: extra brace group at end of initializer
drivers/usb/host/isp1362-hcd.c:3049: error: (near initialization for `isp1362_driver&#39;)
drivers/usb/host/isp1362-hcd.c:3052: warning: excess elements in struct initializer
drivers/usb/host/isp1362-hcd.c:3052: warning: (near initialization for `isp1362_driver&#39;)
drivers/usb/host/isp1362-hcd.c: In function `isp1362_init&#39;:
drivers/usb/host/isp1362-hcd.c:3063: warning: implicit declaration of function `platform_driver_register&#39;
drivers/usb/host/isp1362-hcd.c: In function `isp1362_cleanup&#39;:
drivers/usb/host/isp1362-hcd.c:3070: warning: implicit declaration of function `platform_driver_unregister&#39;
drivers/usb/host/isp1362-hcd.c:3043: error: storage size of `isp1362_driver&#39; isn&#39;t known
drivers/usb/host/isp1362-hcd.c:1581: warning: &#39;isp1362_bus_suspend&#39; declared `static&#39; but never defined
make[3]: *** [drivers/usb/host/isp1362-hcd.o] Error 1
make[2]: *** [drivers/usb/host] Error 2
make[1]: *** [drivers/usb] Error 2
make: *** [drivers] Error 2 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Is diffenence between the isp1362-nios2-01.diff and the isp1362.diff ?
thx in advance !
It is the trouble of back porting. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
The driver code is for 2.6.16.1 .
The include files and data structures are different between 2.6.11 and 2.6.16.1 .
You have to choose to work on either linux-2.6.16.1 or linux-2.6.x (ie 2.6.11-uc0).
More works are required to back port to 2.6.11 .
I am busy now, and can&#39;t help. Sorry.
I have updated the steps of svn. You can use svn to track the debuging.
hi hippo
I have worked on linux-2.6.16.1(using patch isp1362-nios2-01.diff ) that compiled kernel successfully.
i can see isp1362 device form booting messages,but usb device don&#39;t work on my uClinux.
I am working on linux-2.6.x that using patch isp1362.diff right now.
i will try your suggestion on linux-2.6.x,again.
thx in advance!!
jay
hi hippo
I have installed svn on linux-2.6.x and met a problem.
i can&#39;t used the patch "isp1362.diff" in ~/ dir. why?
[jay@localhost ~]$ patch -p0 <~/download/isp1362.diff
patching file include/linux/usb_isp1362.h
can&#39;t find file to patch at input line 52
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|Index: arch/nios2nommu/kernel/usb.c
|--- arch/nios2nommu/kernel/usb.c (revision 12)
|+++ arch/nios2nommu/kernel/usb.c (revision 14)
File to patch:
how to solve this problem?
if i complete the installation of svn.
Is the make kernel also in ~/linux-2.6.x?
thx
--- Quote Start ---
originally posted by jay_1025@Apr 19 2006, 11:00 PM
hi hippo
i have installed svn on linux-2.6.x  and met a problem.
perhaps you used the wrong -p or --strip option?
the text leading up to this was:
|index: arch/nios2nommu/kernel/usb.c
file to patch:
is the make kernel also in ~/linux-2.6.x?
thx
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14482)
--- quote end ---
--- Quote End ---
please do the patch in kernel dir,
cd ~/linux-2.6.x
patch -p0 <.......
You should check the header when you received a patch to know the patch point.
--- Quote Start ---
originally posted by jay_1025@Apr 19 2006, 04:49 PM
hi hippo
i have worked on linux-2.6.16.1(using patch isp1362-nios2-01.diff ) that compiled kernel successfully.
i can see isp1362 device form booting messages,but usb device don&#39;t work on my uclinux.
i am working on linux-2.6.x that using patch isp1362.diff right now.
thx in advance!!
jay
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14478)
--- quote end ---
--- Quote End ---
Maybe you should work on 2.6.16.1 , because the isp1362 driver was fro 2.6.16.1 .
Try debug the driver in 2.6.16.1 .
It is not easy to back port to 2.6.11 , really.
hi hippo
So far, i don&#39;t solve this problem for usb isp1362.
i find two problematic places in isp1362-hcd.c form booting messages to konw , it is "isp1362_hc_reset" and "isp1362_probe". such as following:
Booting messages for usb isp1362
isp1362_hc_reset:
init error, -19
static int isp1362_hc_reset(struct usb_hcd *hcd)
int ret = 0;
struct isp1362_hcd *isp1362_hcd = hcd_to_isp1362_hcd(hcd);
unsigned long t;
unsigned long timeout = 20;
unsigned long flags;
int clkrdy = 0;
INFO("%s:\n", __FUNCTION__);
// dump_regs(s, isp1362_hcd);
if (isp1362_hcd->board && isp1362_hcd->board->reset) {
isp1362_hcd->board->reset(hcd->self.controller, 1);
msleep(20);
if (isp1362_hcd->board->clock) {
isp1362_hcd->board->clock(hcd->self.controller, 1);
isp1362_hcd->board->reset(hcd->self.controller, 0);
} else {
isp1362_sw_reset(isp1362_hcd);
// chip has been reset. First we need to see a clock
t = jiffies + msecs_to_jiffies(timeout);
while (!clkrdy && time_before_eq(jiffies, t)) {
spin_lock_irqsave(&isp1362_hcd->lock, flags);
clkrdy = isp1362_read_reg16(isp1362_hcd, HCuPINT) & HCuPINT_CLKRDY;
spin_unlock_irqrestore(&isp1362_hcd->lock, flags);
if (!clkrdy) {
msleep(4);
isp1362_write_reg16(isp1362_hcd, HCuPINT, HCuPINT_CLKRDY);
if (!clkrdy) {
ERR("Clock not ready after %lums\n", timeout);
ret = -ENODEV;
return ret;
static int __init isp1362_probe(struct platform_device *pdev)
struct usb_hcd *hcd;
struct isp1362_hcd *isp1362_hcd;
struct resource *addr, *data;
void __iomem *addr_reg;
void __iomem *data_reg;
int irq;
int retval = 0;
/* basic sanity checks first. board-specific init logic should
* have initialized this the three resources and probably board
* specific platform_data. we don&#39;t probe for IRQs, and do only
* minimal sanity checking.
if (pdev->num_resources < 3) {
retval = -ENODEV;
goto err1;
data = platform_get_resource(pdev, IORESOURCE_MEM, 0);
addr = platform_get_resource(pdev, IORESOURCE_MEM, 1);
irq = platform_get_irq(pdev, 0);
if (!addr || !data || irq < 0) {
retval = -ENODEV;
goto err1;
# ifdef CONFIG_USB_HCD_DMA
if (pdev->dev.dma_mask) {
struct resource *dma_res = platform_get_resource(pdev, IORESOURCE_MEM, 2);
if (!dma_res) {
retval = -ENODEV;
goto err1;
isp1362_hcd->data_dma = dma_res->start;
isp1362_hcd->max_dma_size = resource_len(dma_res);
}# else
DBG(1, "won&#39;t do DMA");
retval = -ENODEV;
goto err1;
}# endif
if (!request_mem_region(addr->start, resource_len(addr), hcd_name)) {
retval = -EBUSY;
goto err1;
err1:
printk("init error, %d\n", retval);
return retval;
i am not good in usb driver. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Can you tell more detail how to debug it ?
Thx in advance !
jay
--- Quote Start ---
originally posted by jay_1025@Apr 25 2006, 08:48 PM
hi hippo
so far, i don&#39;t solve this problem for usb isp1362.
booting messages for  usb isp1362
isp1362-hcd isp1362-hcd: isp1362 host controller
isp1362_hc_reset:
clock not ready after 20ms
init error, -19
int ret = 0;
unsigned long t;
int clkrdy = 0;
info("%s:\n", __function__);
  msleep(20);
} else {
// chip has been reset. first we need to see a clock
  clkrdy = isp1362_read_reg16(isp1362_hcd, hcupint) & hcupint_clkrdy;
  if (!clkrdy) {
msleep(4);
isp1362_write_reg16(isp1362_hcd, hcupint, hcupint_clkrdy);
if (!clkrdy) {
  err("clock not ready after %lums\n", timeout);
  ret = -enodev;
return ret;
int irq;
int retval = 0;
  * specific platform_data.  we don&#39;t probe for irqs, and do only
  retval = -enodev;
  goto err1;
data = platform_get_resource(pdev, ioresource_mem, 0);
addr = platform_get_resource(pdev, ioresource_mem, 1);
  retval = -enodev;
  goto err1;
# ifdef config_usb_hcd_dma
  struct resource *dma_res = platform_get_resource(pdev, ioresource_mem, 2);
  if (!dma_res) {
retval = -enodev;
goto err1;
}# else
  dbg(1, "won&#39;t do dma");
  retval = -enodev;
  goto err1;
}# endif
  retval = -ebusy;
  goto err1;
        err1:
return retval;
i am not good in usb driver.    http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
can you tell more detail how to debug it ?
thx in advance !
jay
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14647)
--- quote end ---
--- Quote End ---
Please check isp1362 registers access first.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
Check irq pin during the clokc test.[/b]
--- Quote End ---
[/b]
--- Quote End ---
Hi:
I&#39;ve changed a little code in ISP1362-hcd.c, these is my boot message:
--- Quote Start ---
[SOPC Builder]$ nios2-terminal.exe
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.16-uc0 (root@141.71.193.202.in-addr.arpa) (gcc version 3.4.6)# 10 PREEMPT Thu Apr 27 21:18:42 CST 2006
uClinux/Nios II
Built 1 zonelists
Memory available: 6676k/8192k RAM, 0k/0k ROM (982k kernel code, 437k data)
isp1362_hc_reset:
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362-hcd isp1362-hcd: irq 4, io mem 0x80900080
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd: ISTL:    2 *  256:      512 @ $0000:$0100
isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8):  1152 @ $0200
isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8):  2304 @ $0680
isp1362-hcd isp1362-hcd: USED/FREE: 3968    128
usb usb1: Product: ISP1362 Host Controller
usb usb1: Manufacturer: uClinux 2.6.16-uc0 isp1362-hcd
usb usb1: SerialNumber: isp1362-hcd
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 4
Freeing unused kernel memory: 348k freed (0x102000 - 0x158000)
init started:  BusyBox v1.1.1-pre0 (2006.04.21-12:33+0000) multi-call binary
BusyBox v1.1.1-pre0 (2006.04.21-12:33+0000) Built-in shell (msh)
# [/b]
--- Quote End ---
After I plug my usb flash disk, I got these message:
--- Quote Start ---
]# usb 1-2: new full speed USB device using isp1362-hcd and address 2
usb 1-2: Product: USB Mass Storage
usb 1-2: Manufacturer: USB Mass Storage
usb 1-2: SerialNumber: ABCDEF123456789
usb 1-2: configuration# 1 chosen from 1 choice
scsi0 : SCSI emulation for USB Mass Storage devices
  Vendor: USB-disk  Model: FREEDIK-LWFORMAT  Rev: 1.06
  Type: Direct-Access                      ANSI SCSI revision: 00
SCSI device sda: 261856 512-byte hdwr sectors (134 MB)
sda: Write Protect is off
sda: assuming drive cache: write through
sda:<7>usb-storage: queuecommand called
sda1
sd 0:0:0:0: Attached scsi removable disk sda
sd 0:0:0:0: Attached scsi generic sg0 type 0
[/b]
--- Quote End ---
I don&#39;t sure the ISP1362 was working.
I want to access my usb disk by nios2-sdk-shell, what I need to next step?
THX
--- Quote Start ---
originally posted by goral@Apr 27 2006, 09:42 PM
hi:
i&#39;ve changed a little code in isp1362-hcd.c,  these is my boot message:
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
[sopc builder]$ nios2-terminal.exe
nios2-terminal: connected to hardware target using jtag uart on cable
nios2-terminal: "usb-blaster [usb-0]", device 1, instance 0
nios2-terminal: (use the ide stop button or ctrl-c to terminate)
uncompressing linux... ok, booting the kernel.
linux version 2.6.16-uc0 (root@141.71.193.202.in-addr.arpa) (gcc version 3.4.6)# 10 preempt thu apr 27 21:18:42 cst 2006
uclinux/nios ii
altera nios ii support © 2004 microtronix datacom ltd.
built 1 zonelists
kernel command line:
pid hash table entries: 64 (order: 6, 1024 bytes)
dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
memory available: 6676k/8192k ram, 0k/0k rom (982k kernel code, 437k data)
mount-cache hash table entries: 512
scsi subsystem initialized
serial: jtag uart driver $revision: 1.4 $
ttyj0 at mmio 0x81004000 (irq = 1) is a jtag_uart
isp1362_hc_reset:
isp1362-hcd isp1362-hcd: new usb bus registered, assigned bus number 1
isp1362_hc_start:
isp1362-hcd isp1362-hcd: isp1362 memory usage:
isp1362-hcd isp1362-hcd: istl:    2 *  256:      512 @ $0000:$0100
isp1362-hcd isp1362-hcd: intl: 16 * ( 64+8):  1152 @ $0200
isp1362-hcd isp1362-hcd: atl : 32 * ( 64+8):  2304 @ $0680
isp1362-hcd isp1362-hcd: used/free: 3968    128
usb usb1: product: isp1362 host controller
usb usb1: manufacturer: uclinux 2.6.16-uc0 isp1362-hcd
usb usb1: serialnumber: isp1362-hcd
hub 1-0:1.0: usb hub found
isp1362 host controller, irq 4
initializing usb mass storage driver...
usb mass storage support registered.
freeing unused kernel memory: 348k freed (0x102000 - 0x158000)
init started:  busybox v1.1.1-pre0 (2006.04.21-12:33+0000) multi-call binary
busybox v1.1.1-pre0 (2006.04.21-12:33+0000) built-in shell (msh)
enter &#39;help&#39; for a list of built-in commands.
--- Quote End ---
--- Quote Start ---
sda1
[/b]
--- Quote End ---
THX
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14756)</div>
[/b]
--- Quote End ---
Very Good, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
It seems to working. The usb disk is detected. /dev/sda1
You can try "mount -t vfat /dev/sda1 /mnt" .
You don&#39;t need scsi sg device. Only scsi disk is required for usb disk.
Would you attach your updated isp1362-hcd.c (zipped) to my buildroot guide?
Ok, My Lab was closed now , So I haven&#39;t update the program now, I&#39;ll update quickly!
THX for your help!
hi hippo
i can detect the usb flash from booting messages that can&#39;t mount usb flash.
uClinux/Nios II
setup_arch: No persistant network settings signature at 00BF0000
Built 1 zonelists
Memory available: 5968k/8192k RAM, 0k/0k ROM (1577k kernel code, 554k data)
ttyJ0 at MMIO 0x80c81120 (irq = 1) is a jtag_uart
<DM9000> eth0 I/O: 80c81130, VID: 90000a46
isp1362_hc_reset:
isp1362-hcd isp1362-hcd: irq 4, io mem 0x80c810d0
isp1362_hc_start:
TCP reno registered
TCP bic registered
Freeing unused kernel memory: 436k freed (0x19c000 - 0x208000)
init started: BusyBox v1.1.1-pre0 (2006.04.20-12:52+0000) multi-call binary
BusyBox v1.1.1-pre0 (2006.04.20-12:52+0000) Built-in shell (msh)
# Vendor: SigmaTel Model: MSCN Rev: 0001
Type: Direct-Access ANSI SCSI revision: 04
# mount -t vfat /dev/sda1 /mnt
mount: Mounting /dev/sda1 on /mnt failed: No such device# mount -t vfat /dev/hda1 /mnt
mount: Mounting /dev/hda1 on /mnt failed: No such device#
thank in advance !
jay
--- Quote Start ---
originally posted by jay_1025@Apr 27 2006, 11:16 PM
hi hippo
uclinux/nios ii
setup_arch: no persistant network settings signature at 00bf0000
built 1 zonelists
memory available: 5968k/8192k ram, 0k/0k rom (1577k kernel code, 554k data)
net: registered protocol family 16
ttyj0 at mmio 0x80c81120 (irq = 1) is a jtag_uart
dmfe_probe:eth0, 50000 khz nios
<dm9000> eth0 i/o: 80c81130, vid: 90000a46
    addr: 00:07:ed:00:00:00
dmfe_probe:eth1, 50000 khz nios
isp1362_hc_reset:
isp1362_hc_start:
net: registered protocol family 2
ip route cache hash table entries: 128 (order: -3, 512 bytes)
tcp established hash table entries: 512 (order: -1, 2048 bytes)
tcp bind hash table entries: 512 (order: -1, 2048 bytes)
tcp: hash tables configured (established 512 bind 512)
tcp reno registered
tcp bic registered
net: registered protocol family 10
ipv6 over ipv4 tunneling driver
net: registered protocol family 17
freeing unused kernel memory: 436k freed (0x19c000 - 0x208000)
init started:  busybox v1.1.1-pre0 (2006.04.20-12:52+0000) multi-call binary
usb 1-2: new full speed usb device using isp1362-hcd and address 2
scsi0 : scsi emulation for usb mass storage devices
busybox v1.1.1-pre0 (2006.04.20-12:52+0000) built-in shell (msh)
# vendor: sigmatel  model: mscn              rev: 0001
  type: direct-access                      ansi scsi revision: 04
mount: mounting /dev/sda1 on /mnt failed: no such device# mount -t vfat /dev/hda1 /mnt
mount: mounting /dev/hda1 on /mnt failed: no such device#
thank in advance !
jay
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14766)
--- quote end ---
--- Quote End ---
There isn&#39;t sda or sda1 detected.
Did you select scsi disk , and usb mass storage in kernel config?
TO_BE_DONE
TO_BE_DONE
Hi, hippo :
this message I&#39;ve got
--- Quote Start ---
# fdisk -l /dev/sda
Disk /dev/sda: 134 MB, 134070272 bytes
2 heads, 32 sectors/track, 4091 cylinders
Units = cylinders of 64 * 512 = 32768 bytes
Device Boot    Start    End    Blocks Id  System
/dev/sda1            1        4090      130864    4  FAT16 <32M# mount -t vfat /dev/sda1 /mnt
mount: Mounting /dev/sda1 on /mnt failed: No such device# [/b]
--- Quote End ---
After I try to operate like sda1 as sda:
--- Quote Start ---
# fdisk -l /dev/sda1
Disk /dev/sda1: 134 MB, 134004736 bytes
5 heads, 52 sectors/track, 1006 cylinders
Units = cylinders of 260 * 512 = 133120 bytes
/dev/sda1p1 ?  6546149    12813521 814758329+  74  Unknown
Partition 1 has different physical/logical beginnings (non-Linux?):
  phys=(288, 110, 36) logical=(6546148, 2, 41)
Partition 1 has different physical/logical endings:
  phys=(366, 104, 37) logical=(12813520, 1, 31)
Partition 1 does not end on cylinder boundary.
/dev/sda1p2 ?  5116094  7189079 269488144 65  Unknown
Partition 2 has different physical/logical beginnings (non-Linux?):
  phys=(107, 121, 32) logical=(5116093, 0, 13)
Partition 2 has different physical/logical endings:
  phys=(10, 121, 13) logical=(7189078, 3, 44)
Partition 2 does not end on cylinder boundary.
/dev/sda1p3 ?  2073037  7451356 699181456 53  Unknown
Partition 3 has different physical/logical beginnings (non-Linux?):
  phys=(345, 32, 19) logical=(2073036, 0, 32)
Partition 3 has different physical/logical endings:
  phys=(324, 77, 19) logical=(7451355, 0, 3)
Partition 3 does not end on cylinder boundary.
/dev/sda1p4 ?    15035072    15035323    32669+  bb  Unknown
Partition 4 has different physical/logical beginnings (non-Linux?):
  phys=(65, 1, 0) logical=(15035071, 2, 3)
Partition 4 has different physical/logical endings:
  phys=(96, 0, 7) logical=(15035322, 3, 29)
Partition 4 does not end on cylinder boundary.
Partition table entries are not in disk order# [/b]
--- Quote End ---
Maybe the disk wasn&#39;t work?
Could I try other device to replcae the usb flash disk to test the ISP1362?
