USB device!
I have a usb flash disk, I want to using it on my board, I choose USB Mass storage and SCSI disk and ISA116X driver support in menuconfig. Start uClinux on NIOS II SDK shell, using dmesg, I got these message:
# dmesg
Linux version 2.6.11-uc0 (root@localhost.localdomain) (gcc version 3.4.6)# 11 Sa
t Apr 15 17:52:30 CST 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 008F0000
On node 0 totalpages: 2048
DMA zone: 2048 pages, LIFO batch:1
Normal zone: 0 pages, LIFO batch:1
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6188k/8192k RAM, 0k/0k ROM (1334k kernel code, 551k data)
Calibrating delay loop... 24.72 BogoMIPS (lpj=123648)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler deadline registered
dmfe_probe:eth0, 50000 Khz Nios
<DM9000> eth0 I/O: 80900090, VID: 90000a46
ADDR: 00:07:ed:00:00:00
dmfe_probe:eth1, 50000 Khz Nios
Linux video capture interface: v1.00
116x: driver isp116x-hcd, 08 Apr 2005
116x: ISP116x Host Controller, irq 4
isp116x-hcd isp116x-hcd: new USB bus registered, assigned bus number 1
116x: Invalid chip ID 3630
isp116x-hcd isp116x-hcd: USB bus 1 deregistered
116x: init error, -19
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
NET: Registered protocol family 17
Freeing unused kernel memory: 436k freed (0x15e000 - 0x1ca000)#
I plug my usb flash disk in my board usb host port, there is no message appear!
How could I to find the usb disk?
for kernel config,
drivers->scsi->scsi disk support
drivers->usb->usb devices filesystem, usb mass storage .
and you need vfat support as in CF drive.
This is the log of my usb host on pci,
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 2 ports detected
scsi0 : SCSI emulation for USB Mass Storage devices
Freeing unused kernel memory: 372k freed (0x17e000 - 0x1da000)
init started:  BusyBox v1.2.0-pre0 (2006.04.26-14:48+0000) multi-call binary
BusyBox v1.2.0-pre0 (2006.04.26-14:48+0000) Built-in shell (msh)
Enter &#39;help&#39; for a list of built-in commands.
# Vendor: Multi  Model: Flash Reader      Rev: 1.00
  Type: Direct-Access                      ANSI SCSI revision: 00
SCSI device sda: 1997312 512-byte hdwr sectors (1023 MB)
sda: assuming Write Enabled
sda: assuming drive cache: write through
sda: sda1
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0[/b]
--- Quote End ---
--- Quote Start ---
originally posted by goral@Apr 28 2006, 11:52 AM
hi, hippo :
this message i&#39;ve got
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
# fdisk -l /dev/sda
disk /dev/sda: 134 mb, 134070272 bytes
2 heads, 32 sectors/track, 4091 cylinders
units = cylinders of 64 * 512 = 32768 bytes
device boot    start    end    blocks id  system
/dev/sda1            1        4090      130864    4  fat16 <32m# mount -t vfat /dev/sda1 /mnt
mount: mounting /dev/sda1 on /mnt failed: no such device#
--- Quote End ---
After I try to operate like sda1 as sda:
--- Quote Start ---
# fdisk -l /dev/sda1
Disk /dev/sda1: 134 MB, 134004736 bytes
5 heads, 52 sectors/track, 1006 cylinders
Units = cylinders of 260 * 512 = 133120 bytes
  Device Boot    Start    End    Blocks Id  System
/dev/sda1p1 ?  6546149    12813521 814758329+  74  Unknown
Partition 1 has different physical/logical beginnings (non-Linux?):
  phys=(288, 110, 36) logical=(6546148, 2, 41)
Partition 1 has different physical/logical endings:
  phys=(366, 104, 37) logical=(12813520, 1, 31)
Partition 1 does not end on cylinder boundary.
/dev/sda1p2 ?  5116094  7189079 269488144 65  Unknown
Partition 2 has different physical/logical beginnings (non-Linux?):
  phys=(107, 121, 32) logical=(5116093, 0, 13)
Partition 2 has different physical/logical endings:
  phys=(10, 121, 13) logical=(7189078, 3, 44)
Partition 2 does not end on cylinder boundary.
/dev/sda1p3 ?  2073037  7451356 699181456 53  Unknown
Partition 3 has different physical/logical beginnings (non-Linux?):
  phys=(345, 32, 19) logical=(2073036, 0, 32)
Partition 3 has different physical/logical endings:
  phys=(324, 77, 19) logical=(7451355, 0, 3)
Partition 3 does not end on cylinder boundary.
/dev/sda1p4 ?    15035072    15035323    32669+  bb  Unknown
Partition 4 has different physical/logical beginnings (non-Linux?):
  phys=(65, 1, 0) logical=(15035071, 2, 3)
Partition 4 has different physical/logical endings:
  phys=(96, 0, 7) logical=(15035322, 3, 29)
Partition 4 does not end on cylinder boundary.
Partition table entries are not in disk order# [/b]
--- Quote End ---
Maybe the disk wasn&#39;t work?
Could I try other device to replcae the usb flash disk to test the ISP1362?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14792)</div>
[/b]
--- Quote End ---
From your result, the isp1362 should work.
The usb disk is detected, and partition table is correct.
did you enable vfat in kernel config as in step16 of the buildroot guide?
Hi, hippo
Thank for your help, my usb flash disk was working now,, these is my message using on DE II board:
--- Quote Start ---
# usb 1-2: new full speed USB device using isp1362-hcd and address 2
usb 1-2: Product: USB Mass Storage
usb 1-2: Manufacturer: USB Mass Storage
usb 1-2: SerialNumber: ABCDEF123456789
usb 1-2: configuration# 1 chosen from 1 choice
  Vendor: USB-disk  Model: FREEDIK-LWFORMAT  Rev: 1.06
SCSI device sda: 261856 512-byte hdwr sectors (134 MB)
sda: Write Protect is off
sda:<7>usb-storage: queuecommand called
sda1
sd 0:0:0:0: Attached scsi removable disk sda
# mount -t vfat /dev/sda1 /mnt# cd /mnt# ls
DE2_UserManual.pdf# [/b]
--- Quote End ---
I only changed two place in isp1362-hcd.c
--- Quote Start ---
static int isp1362_hc_reset(struct usb_hcd *hcd)
int ret = 0;
struct isp1362_hcd *isp1362_hcd = hcd_to_isp1362_hcd(hcd);
unsigned long t;
unsigned long timeout = 20;
unsigned long flags;
int clkrdy = 0;
                ret = 1;
INFO("%s:\n", __FUNCTION__);
if (isp1362_hcd->board && isp1362_hcd->board->reset) {
  isp1362_hcd->board->reset(hcd->self.controller, 1);
  msleep(20);
  if (isp1362_hcd->board->clock) {
   isp1362_hcd->board->clock(hcd->self.controller, 1);
  isp1362_hcd->board->reset(hcd->self.controller, 0);
} else {
  isp1362_sw_reset(isp1362_hcd);
// chip has been reset. First we need to see a clock
t = jiffies + msecs_to_jiffies(timeout);
while (!clkrdy && time_before_eq(jiffies, t)) {
  spin_lock_irqsave(&isp1362_hcd->lock, flags);
  clkrdy = isp1362_read_reg16(isp1362_hcd, HCuPINT) & HCuPINT_CLKRDY;
  spin_unlock_irqrestore(&isp1362_hcd->lock, flags);
  if (!clkrdy) {
   msleep(4);
isp1362_write_reg16(isp1362_hcd, HCuPINT, HCuPINT_CLKRDY);
if (clkrdy) {
  ERR("Clock not ready after %lums\n", timeout);
  ret = -ENODEV;
return ret;
}[/b]
--- Quote End ---
With best regards!
--- Quote Start ---
originally posted by goral@Apr 28 2006, 02:07 PM
hi, hippo
thank for your help, my usb flash disk was working now,, these is my message using on de ii board:
--- quote end ---
--- quote start ---
# usb 1-2: new full speed usb device using isp1362-hcd and address 2
usb 1-2: product: usb mass storage
usb 1-2: manufacturer: usb mass storage
usb 1-2: serialnumber: abcdef123456789
scsi0 : scsi emulation for usb mass storage devices
  vendor: usb-disk  model: freedik-lwformat  rev: 1.06
  type: direct-access                      ansi scsi revision: 00
scsi device sda: 261856 512-byte hdwr sectors (134 mb)
sda: write protect is off
sda1
sd 0:0:0:0: attached scsi removable disk sda
de2_usermanual.pdf#
--- Quote End ---
--- Quote Start ---
int ret = 0;
unsigned long t;
int clkrdy = 0;
                ret = 1;
  msleep(20);
} else {
  if (!clkrdy) {
msleep(4);
if (clkrdy) {
  ret = -ENODEV;
return ret;
}[/b]
--- Quote End ---
With best regards!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14801)</div>
[/b]
--- Quote End ---
Thank you, too.
So you just bypass the clock check?
hi hippo & goral
I can see usb info( dev/sda1) from booting messages, and can&#39;t mount /dev/sda1 to /mnt . why ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Is it not working ?
ps: i have changed code in isp1362-hcd.c .
uClinux/Nios II
setup_arch: No persistant network settings signature at 00BF0000
Built 1 zonelists
Memory available: 5952k/8192k RAM, 0k/0k ROM (1591k kernel code, 555k data)
io scheduler deadline registered (default)
ttyJ0 at MMIO 0x80c81120 (irq = 1) is a jtag_uart
<DM9000> eth0 I/O: 80c81130, VID: 90000a46
usbmon: debugfs is not available
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362_hc_reset:
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362-hcd isp1362-hcd: irq 4, io mem 0x80c810d0
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100
isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200
isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680
isp1362-hcd isp1362-hcd: USED/FREE: 3968 128
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 4
IP route cache hash table entries: 128 (order: -3, 512 bytes)
TCP established hash table entries: 512 (order: -1, 2048 bytes)
TCP reno registered
TCP bic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
Freeing unused kernel memory: 436k freed (0x1a0000 - 0x20c000)
init started: BusyBox v1.1.1-pre0 (2006.04.20-12:52+0000) multi-call binary
BusyBox v1.1.1-pre0 (2006.04.20-12:52+0000) Built-in shell (msh)
# Vendor: USB 2.0 Model: Mobile Disk Rev: 2.00
Type: Direct-Access ANSI SCSI revision: 02
SCSI device sda: 256000 512-byte hdwr sectors (131 MB)
sda: sda1
# fdisk -l /dev/sda
Disk /dev/sda: 131 MB, 131072000 bytes
16 heads, 32 sectors/track, 500 cylinders
Units = cylinders of 512 * 512 = 262144 bytes
/dev/sda1 * 1 499 127728 6 FAT16# mount -t vfat /dev/sda1 /mnt
mount: Mounting /dev/sda1 on /mnt failed: No such device#
thx in advance !
Hi, hippo
I &#39;m a new user on linux about two months, so I haven&#39;t do more check about device driver, I checked some reg and then I contrast it as the ISP1362&#39;s datasheet, I changed it.Maybe there have antoher problem, when other probelm appearance, I&#39;ll search help and try to solve its.
--- Quote Start ---
So you just bypass the clock check?[/b]
--- Quote End ---
THX!
Hi, jay_1025:
--- Quote Start ---
hi hippo & goral
I can see usb info( dev/sda1) from booting messages, and can&#39;t mount /dev/sda1 to /mnt . why ? sad.gif
Is it not working ?
[/b]
--- Quote End ---
You may check your menuconfig like as hippo mentioned:
--- Quote Start ---
for kernel config,
[/b]
--- Quote End ---
After that, you could do like this:
--- Quote Start ---
File systems -->
DOS/FAT/NT Filesystems  --->
[*] MSDOS fs support
[*] VFAT (Windows-95) fs support
(437) Default codepage for FAT
(iso8859-1) Default iocharset for FAT
Native Language Support -->
(iso8859-1) Default NLS Option
[*] Codepage 437 (United States, Canada)
[*] NLS ISO 8859-1  (Latin 1; Western European Languages)
[/b]
--- Quote End ---
Maybe you can access your usb flash disk!
Lucky! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
hi qoral
thank you for your reply !
final step is very important ! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
I can access usb flash disk(fat 16) on uClinux OS,and the reason that i can&#39;t mount usb flash is file system problem, before.
Can i mount usb flash disk that file system is linux ?
# fdisk -l /dev/sda
/dev/sda1 1 500 127984 83 Linux# mount -t vfat /dev/sda1 /mnt
mount: Mounting /dev/sda1 on /mnt failed: Invalid argument# usb 1-2: USB disconnect, address 2
usb 1-2: new full speed USB device using isp1362-hcd and address 3
scsi1 : SCSI emulation for USB Mass Storage devices
sda: sda1
sd 1:0:0:0: Attached scsi removable disk sda
# fdisk -l /dev/sda
/dev/sda1 * 1 499 127728 6 FAT16# mount -t vfat /dev/sda1 /mnt# cd /mnt# ls
?? S1????.doc nios2.ptf
??1.vsd S1??????0411.doc nios2_system.h
????10 app_self nios_1.ptf
????2.doc ice zImage
Filesystem_1c20_usr jay_??#
thx in advance !
I&#39;m glad to hear your success, Maybe you could try your thought, I didn&#39;t do that, I want to using the usb host port for my camera, If you interesting, we can help each other!
Are u want to try?
I am very happy with the success of you both. Help each other, please. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
If you want to mount Linux disk partition or others, you can enable them in kernel config,
file system -> ext2 or ext3 or others .
You should enable only the options which you will use. But don&#39;t enable too much, the kernel size will grow, take more memory and take longer time to boot.
--- Quote Start ---
originally posted by goral@Apr 28 2006, 07:33 AM
i&#39;m glad to hear your success, maybe you could try your thought, i didn&#39;t do that, i want  to using the usb host port  for  my camera, if you interesting, we can help each other!
are u want to try?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14818)
--- quote end ---
--- Quote End ---
hi groal
OK,we can discuss usb port for camera and help each other.
what kind of purposes do you want to implement on DE2 board ?
my lab have two 1.3Mega Pixel Digital Camera modules for DE2 ,and can implement real-time movement detecting . my classmate want to use usb camera that implement the same purpose.
so, do you have interests in real-time movement detecting with using usb camera ?
--- Quote Start ---
hi groal
so, do you have interests in real-time movement detecting with using usb camera ?[/b]
--- Quote End ---
Hi : jay_1025
Thanks for your enjoy, I didn&#39;t so high Pixel Digital Camera modules, today I buy a 0.3Mega Pixel Digitial Camera which using ov511 IC on a onilne shop, Maybe 2-days later I will do my lab continue, I read some program for capture video data such as V4L now, I want to capture some video and compress them by some mpga4 algorithm and storage them in USB flash disk, and then I want to see the realtime video on my tuochscreens or transform on the internet.
Maybe like a video phone http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif ,Like as I done on ARM9 platform before!
We can help each other!
Regards!
--- Quote Start ---
--- quote end ---
--- quote start ---
hi groal
ok,we can discuss usb port for camera and help each other.
what kind of purposes do you want to implement on de2 board ?
my lab have two 1.3mega pixel digital camera modules for de2 ,and can implement real-time movement detecting . my classmate want to use usb camera that implement the same purpose.
--- Quote End ---
Hi : jay_1025
Regards!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14864)</div>
[/b]
--- Quote End ---
Just one question : if you have already done this work on an ARM9 platform, why do you want to port this to the NIOS platform ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
--- Quote Start ---
Just one question : if you have already done this work on an ARM9 platform, why do you want to port this to the NIOS platform ? rolleyes.gif[/b]
--- Quote End ---
Hi bigboss25:
Its a very fun question, my answer is very simple, I&#39;m a student in a college, I want to master more knowledge only!
I want to contrast the different platform, now I prefer like nios, Its full of Challenge when I solve some problem, In furture, I think NIOS will have a good chance in many areas, if we can intergate two or more CPU on our FPGA ,lsuch as DSP or other . We&#39;ll get the most effective than other singel CPU platform. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
--- Quote Start ---
--- quote end ---
--- quote start ---
just one question : if you have already done this work on an arm9 platform, why do you want to port this to the nios platform ? rolleyes.gif
--- Quote End ---
Hi bigboss25:
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14866)</div>
[/b]
--- Quote End ---
Hi Goral,
you seems to be already a wise man, and I totally agree with you http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif .
I&#39;ve the same point of view but do you think NIOS can compete with ARM9 ?
Can you explain your preference for NIOS ?
Regards.
--- Quote Start ---
Hi Goral,
you seems to be already a wise man, and I totally agree with you biggrin.gif .
Regards.[/b]
--- Quote End ---
Hi bigboss25
Thanks for your Praise&#65292; http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
Of course I think NIOS must be compete with ARM, but NIOS must be advantage itself in furture. I&#39;m a new man about NIOS and uCliunx, so I want to using NIOS&uClinux to achieve a video phone or other usful thing.
If you are interestig NIOS & uCLinux, We can help each other! Could I search help for you when I occur some problem?
Regards!
hi qoral
i have TRDB_DC2 hareware module support the DE2 board, but i don&#39;t add TRDB_DC2 hardware to Nios2 cpu in SOPC Builder yet.
i don&#39;t seems easy to add it with nios2 cpu in SOPC builder.
Do you know how to add it with nios2 cpu in SOPC builder ?
if you want to try it and i will send hardware project(without nios2 cpu) to you.
Reference design website for DE2
trdb_dc2 - 1.3mega pixel digital camera module for de2/trex c1 (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=39&no=50
jay
hi
i tried out the new isp1362-hcd.c changes and uclinux boots up nicely - thx goral and jay_1025!
i can see the files on my usb stick now, thx guys!
shindou
--- Quote Start ---
hi qoral
TRDB_DC2 - 1.3Mega Pixel Digital Camera Module for DE2/TREX C1
jay[/b]
--- Quote End ---
Hi jay_1025
I&#39;m I dodn&#39;t have TRDB_DC2 - 1.3Mega Pixel Digital Camera Module, and I haven&#39;t any resource about it. So I couldn&#39;t do it now http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
I backported the isp1362-hcd.c to Microtronix 2.6.11 kernel from the
isp1362.diff
The whole procedure is described on my homepage
http://www.8ung.at/nacide_manfred/linuxtutorial.html (http://www.8ung.at/nacide_manfred/linuxtutorial.html)
Hello...
Please Help as I think you people can..
I am curently working on IP08 board made by Rowetel and it has BF532 and ISP1362 controller for USB. The Problem I am facing is that I am able to use normal USB Mass storage devices they are detected by the system (uClinux 2009 dist).
i.e. it prints a message saying usb 1-2: new full speed USB device using isp1362-hcd and address 2
usb 1-2: New USB device found, idVendor=0951, idProduct=160b
usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-2: Product: DataTraveler2.0
usb 1-2: Manufacturer: Kingston
usb 1-2: SerialNumber: 0802101904166
uncorrectable error : <3>uncorrectable error : <3>uncorrectable error : <3>unco2
sd 0:0:0:0: [sda] 7806847 512-byte hardware sectors: (3.99 GB/3.72 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
and at this point
root:/proc/bus/usb> cat devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%),# Int= 0,# Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64# Cfgs= 1
P: Vendor=1d6b ProdID=0001 Rev= 2.06
S: Manufacturer=Linux 2.6.28.10-ADI-2009R1.1 isp1362-hcd
S: Product=ISP1362 Host Controller
S: SerialNumber=isp1362-hcd.0
C:*# Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0# EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64# Cfgs= 1
P: Vendor=0951 ProdID=160b Rev= 1.00
S: Manufacturer=Kingston
S: Product=DataTraveler2.0
S: SerialNumber=0802101904166
C:*# Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I:* If#= 0 Alt= 0# EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
But when I try to attach MP3 Player or Nokia Phone it does not even show symptoms of being attached to usb port. Although I have compiled ISP1362-HCD and enabled the cdc-acm support as well. Kindly guide me whether it is feasible or not, If yes then where the problem is.
