12603 Discussions
USB setup for Linux on Arrow Sockit
I've installed the GSRD 14, I've built my FPGA core and I've got them communicating.
Next I need to get some keyboard input. So I bought a USB OTG to USB adaptor. I've plugged in the keyboard but Linux does not appear to recognise it. I see these in dmesg:
usbcore: registered new interface driver usbfsusbcore: registered new interface driver hub
usbcore: registered new device driver usb
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
However the rest does not seem to be set up:
>lsusb
unable to initialize libusb: -99
>ls /dev/bus/usb
ls: /dev/bus/usb: No such file or directory
>ls /proc/bus/usb
ls: /proc/bus/usb: No such file or directory
I also see nothing in dmesg when connecting/disconnecting devices.
Should this work with the default kernel? Or do I need to build my own to get this working?
I saw other distributions with USB mouse/keyboard etc, though these seem to also need the FPGA side configured for video. I have my own FPGA side configuration.
Any tips greatly appreciated! I might go any try one of the 'full computer' style distributions to at least check my board/cable works in the meantime...
Just to be clear is no-one replying because this is a stupid question and I should know better/RTFM? Or has no-one actually got USB working with the GSRD standard install?
I've come to the conclusion I need to rebuild the kernel with some additional options enabled/modules. Unfortunately altera yocto requires an old version of Debian - Jessie is too new. I tried to build it anyway but there is just too much to patch to be practical.
Its kind of funny because I've been working much lower level - with zpu soft core and usb using the usbhostslave from open cores. Bizarrely it is much simpler to make that work just driving the d+/d- than it is to get USB working in the SOCkit from linux!
