12471 Discussions
Uart returning -1 when more than 1 uart opened in NIOS
hi,
I am using quartus 9.0.
and I need to use 5 uart cores in sopc (all 115200). when i am opening one uart in blocking mode in Nios, it reads/writes fine. bt wen i start opening other uarts, the same port starts returning -1 (only opening of other ports,no reading no writing).
I need to use all rs-232 ports..wat can be the problem?
sth like this
main()
uart1=open(uart1_name, mode)
uart2=(uart2_name, mode)
result=read(uart2, buffer, len) //gives error if uart1 is opened before uart2, alone it works fine.
I need to use all 5 rs-232 ports..wat can be the problem?:confused:
can we use only one uart core??:confused:
plz reply.
my problem is still not solved... plz helppppp......
If you post your question in the correct forum then you'll probably get better help. Moving to the Nios II forum....
