Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Uboot + Stratix EP1S40 + nios2
I am trying to download the u-boot.bin file that I created using debian linux with gnu cross-compiler for uclinux.
I am using nios-II command line utility program that comes with altera NIOS-II IDE ...which I downloaded from their website.
After running this command " bin2flash --input=u-boot.bin --output=u-boot.flash --base=0x00000000 --flash=U5 --location=0x0
I got a file "u-boot.flash"
when I was trying to run "nios2-flash-programmer --base=0x00000000 --input=u-boot.flash --sof=standard.sof --verbose
NOTE:---- The "standard.sof" file came with altera's software for "niosII_stratix_1s40" board.
I got an error....which is copied below:
Errors
Aug 2, 2005 9:53:16 PM - (FINE) nios2-flash-programmer: nios2-flash-programmer starting
Aug 2, 2005 9:53:16 PM - (INFO) nios2-flash-programmer: args = --base=0x00000000
Aug 2, 2005 9:53:16 PM - (INFO) nios2-flash-programmer: Attempting to read input-data from u-boot.flash
Aug 2, 2005 9:53:17 PM - (INFO) nios2-flash-programmer: Launching Quartus Programmer to download:standard.sof
Aug 2, 2005 9:53:17 PM - (FINE) nios2-flash-programmer: Quartus Pgm launched
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Command: quartus_pgm --no_banner --mode=jtag --operation=p;standard.sof
Info: Using programming cable "ByteBlasterII [LPT1]"
Info: Started Programmer operation at Tue Aug 02 21:53:23 2005
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020050DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Tue Aug 02 21:54:06 2005
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Processing ended: Tue Aug 02 21:54:06 2005
Info: Elapsed time: 00:00:47
Aug 2, 2005 9:54:06 PM - (FINE) nios2-flash-programmer: SOF programming done. ex
it code = 0x0000
Connecting with target design
Attempting to resynch with target
Send (64) failed.
Unable to synchronize with target.
Aug 2, 2005 9:54:26 PM - (SEVERE) nios2-flash-programmer: Error opening target hardware
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-bui
lt flash-programming designs pre-built for several development boards. If you wi
sh to program flash on your own board, you must first create a flash-programming
End
Anyone has an idea what's going on.??
Highlighted
Re: Uboot + Stratix EP1S40 + nios2
Hi haq,
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
NOTE:---- The "standard.sof" file came with altera&#39;s software for "niosII_stratix_1s40" board.[/b]
--- Quote End ---
I believe the standard.sof file is just a II/s example design -- not a flash programmer design.
Try using the the file altera_nios_dev_board_stratix_1s40.sof from the directory
altera/kits/nios2/components/altera_nios_dev_board_stratix_1s40/system
I&#39;m assuming you&#39;re using the 1s40 development kit of course ;-)
--Scott
Highlighted
hi scott,
i want to flash a EP1S25 board.
Any idea where i can start to write the programming file because there isnt any support for this on NIOSII IDE.
Highlighted
I think you are looking for mk_target_board.
Highlighted
Hi Toysoldier,
Markus is correct, you need to use mk_target_board
You should read Chapter 2 in "Nios II Flash Programmer User Guide" -- it is a
very useful doc :-)
http://www.altera.com/literature/ug/ug_nio..._programmer.pdf (http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf
--Scott
