12604 Discussions
Unable to add BSP after subversion switch
Hello there,
I have a Nios2-Project running for a while now, and do organize my code with subversion. There's everything checked in, even the project settings and .metadata from eclipse. Yesterday I switched to a branch for the first time with this project and now i cannot specify a Nios BSP and so i do get the following compiler error
make all makefile:312: *** Edit Makefile and provide a value for BSP_ROOT_DIR. Stop.
I even switched back to my original location.
Now every time i open the Project Properties->Nios2 Application Properties every field is blank. So i can specify the BSP but if i close the properties and reopen, everything is gone. So it seems, that there is a Problem writting to the settings.
Does anybody know, which file is used by eclipse to stroe these settings, so maybe i'll just delete it.
My Configuration:
Win7 64Bit
Nios EDS 12.0.178
I run Eclipse as administrator
Hi there,
it's me again:
So after i got rid of the daily madness at work, i got a few more minutes to spend on the problem:
I fond that in the makefile the following:
ACTIVE_BUILD_CONFIG := default BUILD_CONFIGS += default BUILD_CONFIGS += Release include $(ACTIVE_BUILD_CONFIG)_config.mk
was reduced to:
So that the default_config.mk wasn't used anymore, which is btw the file which holds all the Nios Application Properties.
So now i do have to figure out, why this was lost. It may be, that my colleague, who created the svn branch, does have an older version, which do not use these _config.mk
But anyway, iam glad it works now!
