Hello All,
I have a DE2-115 running a Nios-II S(low) with the on board SDRAM (basic config, HELLO WORLD application). 50 Mhz clock, 3ns delay for the ram clock, no FPGA RAM used. When I change to Nios-II-F(ast), using the same configuration I am unable to start the CPU (an exception is thrown at startup). I wonder what can be the reason ? What is a bit strange is that the OpenCore dialog box (Quartus Lite Edition 17.0) does not come up when I download. I know that the Slow CPU does not need the Open Core licence (as it seems), but I thought that the F version did. If so, how can I convince Quartus to launch OpenCore upon download of my VHDL project ? To be sure there are no hickups in Eclipse, I generate a new program based on the SOPC file generated by QSYS, so I do not use an updated BSP to start from when changing the CPU type. The old configuration cannot pollute the new one. The exact error I get is that Nios throws an exception and ends up at Nios2_BREAK() (alt_instruction_exception_entry.c). This after I oblige eclipse to download by overruling the timpmestamp check that is not correct.) Since I generated a brand new file based on a newly generated Sopc file, this also seems very strange. Iam also very sure I download the correct version to my FPGA board. (tried it multiple times) Backtracking on the stack, the exception seems to be generated in alt_get_fd.c, getting a descriptor for my Jtag Uart. Very strange because for the -S CPU this works properly ? The exact line is line 79 where alt_fd_list.dev is accessed.for (i = 0; i < alt_max_fd; i++)
if (!alt_fd_list.dev) <= this line { alt_fd_list[i].dev = dev; if (i > alt_max_fd) { alt_max_fd = i; } rc = i; goto alt_get_fd_exit; } Is there anybody who got the -F cpu working on an SDRAM config for the DE2-115 in a Quartus lite config? Is anybody able to explain what I did wrong or forgot ? Thanks for any advice, Johi.
Dear All,
My mistake: You can select 2 different versions of the .sof file to download to the FPGA. The standard version The time limited version. For the /f cpu you need the time limited version in Q lite. And for those of you struggeling with a DE2-115 Nios-II/F. I included a Q17.0 archive of my working project. Best Regards, Johi.
