I am unable to run SoCEDSSetup-14.0.0.200-linux.run, this is on an ubuntu 3.2.0-63-generic-pae# 95-Ubuntu SMP Thu May 15 23:26:11 UTC 2014 i686 i686 i386 GNU/Linux.
I have chmod +x to the file and I am root. The error is "cannot execute binary file" Has anyone else had this porblem and how was it resolved? ThanksLink Copied
found to be a 64bit/32bit problem, dropped back to previous release
So you dropped back to 13.1 ???
I have a same problem. I just install xubuntu 14.04 64 bit only because of this and now I am facing 32bit lib dependency problems :/- Mark as New
I tried 13.1, and it still does not work. The file does not even open.
Any ideas?- Mark as New
I have done some tryouts and what worked for me was:
13.1 on Xubuntu 12.04 32bit 14.0 on Xubuntu 12.04 64bit 14.0 on Xubuntu 14.04 64bit An as you said $chmod +x <file> and than sudo ./<file> And what was output from 13.1 on your machine?- Mark as New
For Linux you really need to check the install instructions. There are several libraries that are not installed in Linux by default that the Altera tools need. I think they have to do with running 32 bit apps built for older versions. Also, I don't think Ubuntu is a supported Linux distro for the Altera tools although I've heard that people have gotten it to work. I personally use Centos (based on redhat) and the tools work fine.
If you would like to use Ubuntu based distro with Altera 14.0 and above, I would reccommend 12.04 64bit because you are able to install ia32-libs package (has been replaced by lib32z1 lib32ncurses5 lib32bz2-1.0 from Ubuntu 13.04) and you get all you need basically. Otherwise you have to install all missing packages by
$ sudo apt-get install package:i386 And at the end of installation you should get a listing if you are missing some of the libraries.- Mark as New
I installed Ubuntu 12.04 over 6 mo. ago using instructions from http://rocketboards.org/foswiki/documentation/gsrd131gettingstartedyocto#obtaining_yocto_source_package and it went smooth as cream, including sudo apt-get install ia32-libs. Now trying to setup new laptop with Ubuntu 12.04 (as stated on the aforementioned Rocketboards page, so I assume it is supported by Altera tools Galfonz) using the same rocketboard instructions - this time sudo apt-get install ia32-libs is not available. As a result, SoCEDSSetup-14.1.0.186-linux.run does not run.
I tried sudo apt-get install package:i386, but get 'unable to locate that package'. If anyone knows what to try next I would appreciate it.- Mark as New
Seems strange. I know it's matter of course but are you sure you installed 64bit version??? Otherwise try to search why are you not able to install 32bit libraries.
Did a complete reinstall of 32 bit Ubuntu 12.04, just in case with all my messing around some wires got crossed.
Verified it is 32 bit from >Settings Installed the update, upgrade, etc. listed under Getting Started with Yocto - Ubuntu 12.04 on the RocketBoard.org page (http://www.rocketboards.org/foswiki/documentation/gsrd131gettingstartedyocto) Did not install the ia32-libs, because as I understand it, it is only needed for 64 bit installs Downloaded the the SoC EDS. Comes as a .run Did a chmod +x, on it, tried to run, (i.e. ./SoCEDS ...), get a "cannot execute binary file" Tried >sudo ./SoCEDS...run , got Syntax error: "(" unexpected From what I can Google, the "(" Syntax error has something to bash vs. dash, so I ran >sudo bash ./SoCEDS...run, and I get "cannot execute binary file" Did a few permutations, i.e. sometimes with ,/, sometimes no sudo, always with bash, but result always "cannot execute binary file". Redid the first few install steps - no difference, because everything already was installed. Tried to install ia32-libs, but would not install ... which I expected. Same with package:i386 Most searched responses have chmod +x fixing the issue. I ran >ls -l and saw that the file attributes had x set. (-rwxrwxr-x) Any advice most appreciated.- Mark as New
--- Quote Start --- Did a complete reinstall of 32 bit Ubuntu 12.04, just in case with all my messing around some wires got crossed. Verified it is 32 bit from >Settings Installed the update, upgrade, etc. listed under Getting Started with Yocto - Ubuntu 12.04 on the RocketBoard.org page (http://www.rocketboards.org/foswiki/documentation/gsrd131gettingstartedyocto) Did not install the ia32-libs, because as I understand it, it is only needed for 64 bit installs Downloaded the the SoC EDS. Comes as a .run Did a chmod +x, on it, tried to run, (i.e. ./SoCEDS ...), get a "cannot execute binary file" Tried >sudo ./SoCEDS...run , got Syntax error: "(" unexpected From what I can Google, the "(" Syntax error has something to bash vs. dash, so I ran >sudo bash ./SoCEDS...run, and I get "cannot execute binary file" Did a few permutations, i.e. sometimes with ,/, sometimes no sudo, always with bash, but result always "cannot execute binary file". Redid the first few install steps - no difference, because everything already was installed. Tried to install ia32-libs, but would not install ... which I expected. Same with package:i386 Most searched responses have chmod +x fixing the issue. I ran >ls -l and saw that the file attributes had x set. (-rwxrwxr-x) Any advice most appreciated. --- Quote End --- To clarify - this is with the 14.1 EDS (SoCEDSSetup-14.1.0.186-linux.run), not the 14.0 version in the title of this thread
Installed Ubuntu 12.04 64 bit - now I can launch SoCEDSSetup-14.1.0.186-linux.run. The Quartus stuff did not install (permission issues), but I'm not interested in FPGA just yet. Found that I had to run ../(ESD_Workspace)/embedded/ds-5_installer/Install.sh after SoCEDSSetup-14.1.0.186-linux.run to complete the install (you need to run Install.sh as root).
Another interesting note - Install.sh would not run without errors until I accepted all the defaults. The only default I had tried to change was the location of the tools - I have a dual boot workstation and I was trying to put as much as I could in the FAT32 partition I set up for sharing (it is by far the largest). The default location is in Linux root partition (EXT4) and that seems to be required. So now whenever I run ANY script from Altera I accept all the defaults, because I suspect they don't test much other than that.- Mark as New
Good to know you make it run. Strange thing is they require 64bit distro with 32bit libraries...
as i heard only certain version of ubuntu is good to go for SOCEDS.
