hello everyone,
every time i wan't to run my program on nios 2 eclipse ide I got this error
Error starting process.
Cannot run program "C:\Users\youss\OneDrive\Bureau\tp_VHDL_G2_B5\de0_nano\sopc_compteur\software\test_compteur\test_compteur.elf": Launching failed
can someone help me please.
Hello Leond,
in this case, please check that you have these variables on the following path. Project->properties->C/C++ General->Paths and Symbols in the "include" tab I had to add the following directories.
In "GNU C":
- $MINGW_HOME\lib\gcc\mingw32\4.6.x\include
- $MINGW_HOME\include
- $MINGW_HOME\lib\gcc\mingw32\4.6.x\include-fixed
In "GNU C++" :
- $MINGW_HOME\lib\gcc\mingw32\4.6.x\include\c++
- $MINGW_HOME\lib\gcc\mingw32\4.6.x\include\c++\mingw32
- $MINGW_HOME\lib\gcc\mingw32\4.6.x\include\c++\backward
Isaac Vazquez.
Did the solution works for you?
Isaac Vazquez.
