Unsupported Phy bug
Hi Guys,
I am trying to connect the micrel ksz8081 phy to cyclone altera using the
TSE mac based on simple socket server ( by nichestack ).
I used a file called "tse_my_sysetm.c"(attached) -cause this phy is not supported in the nios sw.
from some reson the phy to mac mapping failes-and i am not able to ping from PC to FPGA mac.
The nios prints:# ################################################################
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Can't read the MAC address from your board. We will assign you
a MAC address.
Your Ethernet MAC address is 00:07:ed:24:01:5e
Static IP Address is 10.0.1.3
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x00143000
INFO : PHY Micrel KSZ8081MNXIA found at PHY address 0x00 of MAC Group[0]
WARNING : PHY[0.X] - Mapping of PHY to MAC failed! Make sure the PHY address is defined correctly in tse_mac_device[] structure, and number of PHYs connected is equivalent to number of channel
INFO : PHY Micrel KSZ8081MNXIA found at PHY address 0x01 of MAC Group[0]
INFO : PHY[0.0] - Explicitly mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
WARNING : PHY[0.0] - Auto-Negotiation FAILED
PHY reset
Configuration written to PHY register 0
Configuration written to PHY register 1F
PHY reset
WARNING : MAC Group[0] - Number of PHY connected is not equal to the number of channel, Number of PHY : 2, Channel : 1
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link not yet established, restart auto-negotiation...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PHY[0.0] - Link established
WARNING : PHY[0.0] - Invalid speed read from PHY
INFO : PHY[0.0] - Speed = Unknown, Duplex = Half
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000603
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 10.0.1.3
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 7003
Created "simple socket server" task (Prio: 4)# ################################################
Can anyone advise on how to integrate this phy to the altera TSE mac based on the simple socket server software?
