After update nios-linux 20100621, when i make, get error :
{standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/memory.o] Error 1 make[2]: *** [arch/nios2/mm] Error 2 make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/root/nios2-linux/linux-2.6' make: *** [linux] Error 1 Who knows to help me?Link Copied
Got same error when starting to play around with uclinux some time ago.
Hope I remember right when I tell you to check a) your branches b) your toolchain So when working without mmu you should use nios2gcc-20080203.tar.bz2 and test-nios2 branches, when working with mmu you should use toolchain-mmu and branches trunk (uClinux-dist) / nios2 (linux-2.6) Hope this helps. Andi- Mark as New
I'm sure to use nios2gcc-20080203.tar.bz2 and test-nios2 branches (uClinux-dist & linux-2.6)
and i make succesfull but not detected USB 1-0 : 1 port detected ,so i try to update and get above error can you see my post and help me http://www.alteraforum.com/forum/showthread.php?t=34708- Mark as New
I solved this problem with mount USB on uclinux and you shouldn't update source
A quick 'RTFM' shows that the 'initda' instruction was added in rev 8.0 in May 2008. So it is likely that the toolchain you are using predates that change.
--- Quote Start --- After update nios-linux 20100621, when i make, get error : {standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/memory.o] Error 1 make[2]: *** [arch/nios2/mm] Error 2 make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/root/nios2-linux/linux-2.6' make: *** [linux] Error 1 --------------------------------------------------------------------------------------------- Hallo kinhcan89, can u tell me how did you solve this Problem? i am having the same one! i Know its one year ago but maybe u remember :-).
--- Quote Start --- --- Quote Start --- After update nios-linux 20100621, when i make, get error : {standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/memory.o] Error 1 make[2]: *** [arch/nios2/mm] Error 2 make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/root/nios2-linux/linux-2.6' make: *** [linux] Error 1 --------------------------------------------------------------------------------------------- Hallo kinhcan89, can u tell me how did you solve this Problem? i am having the same one! i Know its one year ago but maybe u remember :-). --- Quote End --- Which toolchain do you use and which branch do you use (mmu / nommu)?
--- Quote Start --- --- Quote Start --- Which toolchain do you use and which branch do you use (mmu / nommu)? --- Quote End --- I am using pre-build toolchain nios2gcc-20080203.tar.bz2 and test-nios2 branches(uClinux-dist and Linux-2.6).
--- Quote Start --- --- Quote Start --- I am using pre-build toolchain nios2gcc-20080203.tar.bz2 and test-nios2 branches(uClinux-dist and Linux-2.6). --- Quote End --- I can remember that this was the wrong toolchain for systems with mmu. nios2gcc-20080202 prebuilt toolchain was for use with nommu-systems. The error message you posted looks like this is the problem here, too.
--- Quote Start --- --- Quote Start --- I can remember that this was the wrong toolchain for systems with mmu. nios2gcc-20080202 prebuilt toolchain was for use with nommu-systems. The error message you posted looks like this is the problem here, too. --- Quote End --- My Hardware Architect don't have on chip memory, I am using nommu system.
Maybe you should build the tool chain like:
cd nios2-linux/toolchain-build git clean -f -x -d# clean on restart make gcc make elf2flt Then,use the new compiler you made. PATH=$PATH:/home/(user name)/nios2-linux/toolchain-build/build/nios2/bin Regards.- Mark as New
Sorry to annoy you all but I'm trying to build the uClinux on DE2 Cyclone 2 (an old kit). I've had the same error and as far as I realized this is because the nios-linux version is new (nios2-linux-20120802) so may be it's not compatible with the NO MMU. However, I can't find any old version of this file like nios-linux-20090730 since all the links died. So anyone can show me how to fix the problem or provide with the link to download the old version to test.
Thank you all.
