I have been useing Niso IDE for a few weeks. I notice that it bases on Eclipse IDE 2.1 and CDT plugin 1.2.1. Since I am user of Eclipse 3.0 with CDT plugin 2.0, I wonder if I can use CDT2.0 with Nios IDE. Or should I upgrade the Nios IDE to versiion 3.0. If yes, could any one tell me how to upgrade? thanks in advance Kwok Wong (kwo@chess.nl)Link Copied
Someone else will be better at answering this, but I'll give it a try.
I believe that you cannot just upgrade to a newer version. The plugins we use just won't work. I'll see if someone else can explain it better.- Mark as New
Kerri is correct. We will be upgrading to newer versions of Eclipse which will be incorporated as part of Nios II IDE for upcoming release from Altera.
