12454 Discussions
Use DS-5 AE Bare-metal for C code programming on DE0-NANO_SOC
I am trying to use DS-5 AE Evaluation for C code programming on DE0-NANO_SOC. when I load preloader the following message will be appeared:
Stopping running target Altera - Cyclone V SoC (Dual Core) on TCP:localhost on connection
Connected to running target Altera - Cyclone V SoC (Dual Core) on TCP:localhost
Execution stopped at: S:0x00002FA8
source /v "C:\altera\15.0\embedded\ds-5\sw\debugger\configdb\Scripts\altera_target_check .py"
S:0x00002FA8 TST r1,#4
No SYSID registers could be found. Has a peripheral description file been supplied?
load "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5\test\u-boot-spl"
Loaded section .text: S:0xFFFF0000 ~ S:0xFFFF6AA3 (size 0x6AA4)
Loaded section .rodata: S:0xFFFF6AA4 ~ S:0xFFFF8672 (size 0x1BCF)
Loaded section .data: S:0xFFFF8678 ~ S:0xFFFF954B (size 0xED4)
Entry point S:0xFFFF0000
cd "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5"
Working directory "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5"
set debug-from *$ENTRYPOINT
start
Starting target with no symbolic information loaded
Execution stopped at: S:0xFFFF0000
wait
S:0xFFFF0000 B {pc}+0x70 ; 0xffff0070
Run
Pause 1s
Interrupt
Execution stopped at: S:0xFFFF475C
S:0xFFFF475C B {pc} ; 0xffff475c
Quit
Disconnected from stopped target Altera - Cyclone V SoC (Dual Core) on TCP:localhost
but The following problem will be appeared for loading test.axf:
loadfile "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5\test\Debug\test.axf"
ERROR(CMD16-TAD274-NAL22):
! Failed to load "test.axf"
! Failed to write 4,884 bytes to address S:0x00200000 while writing block of 4,096 bytes to address S:0x00200000
! General error on memory or register access.
set debug-from main
start
WARNING(CMD399-COR168):
! Failed to start the target
! No function named "main" could be found
WARNING(CMD407): Trying the entry point instead
ERROR(CMD426): Cannot find symbol to start or entrypoint, the file or load commands may be used to set the entrypoint
wait
Target Message: Could not determine target state
How can I solve this problem ? the workspace of the DS-5 of the project is attached.
