Folks,
Has anybody set up Visual C++ to run a cygwin makefile before. I am getting it running but the environment is not correct, it cant find some files/libs.Link Copied
Edward,
My FAE sent me a pseudo app-note concering just that. I will email it to you if you give me your email address (the internal email doens't support attachments). dave- Mark as New
maybe you could copy the text to this discussion? It might be helpful to others.
Update:
Dont bother with VC++, just use the NIOS II IDE. Its just as good, even better for NIOS dev. Altho it does not target NIOS I out of the box, you can make a NIOS II run faster and use less LEs. The NIOS I/16 I was using was about 1/8 the speed of my NIOS II/e for about half the LEs.
