12435 Discussions
Verified OK - Leaving target processor paused
I have got a problem when running Nios, here is my problem:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloading 00008000 ( 0%)
Downloaded 19KB in 0.3s (63.3KB/s)
Verifying 00008000 ( 0%)
Verified OK
I have read some comments by similar stuffs, but there was no any solutions for this ? Can anybody show me what this problem is ? Since it reported no error but the result was nothing.
I highly appreciate any comments from you.
DucKhai.
How do you download the .elf file to the Nios? If using the command line you need to add the -g option to start the CPU after download. If you are using a GUI there may be a box to tick to do that.
This could be a pin assignment issue. Ensure that clk and reset are connected to the respective pins in the board.
For DE4, I found that assigning clk to pin OSC_50_B7 (50 Mhz clk input for Bank 7c 1.8v pin A19) worked.
Also, I think the frequency of clk input from board must match frequency in SOPC builder (50MHz usually) unless you are using an exclusive PLL
